This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Roomba i7 - Change base return sensor
Video Overview
  1. Roomba i7 - Change base return sensor, front señor: step 1, image 1 of 1
    • Remove the dust collector. Disassemble the 6 screws marked in blue. Then remove the brush spotted with the orange arrow. You can then remove the bottom of the robot
    • Remove the 10 screws marked in red. You can remove the bottom cover of the front "bumper".
  2. Roomba i7 - Change base return sensor: step 2, image 1 of 1
    • The lower cover of the bumper is removed. By lifting the robot you will be able to clear the "bumper" to access the sensor.
  3. Roomba i7 - Change base return sensor: step 3, image 1 of 2 Roomba i7 - Change base return sensor: step 3, image 2 of 2
    • You must then unplug the sensor connector from your card. There are 2 screws to remove to disassemble the sensor
  4. Roomba i7 - Change base return sensor: step 4, image 1 of 1
    • Here is the sensor that is easily found for sale on the internet by searching for "RCON Certified iRobot i7 Sensor Kit"
Mount the new sensor in the "bumper", connect it to its card
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
75%
Steph is helping us fix the world! Want to contribute?
Start translating ›
Steph
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 38
Past 30 Days: 118
All Time: 623
