Change the thermal breaker - Sterwins HC 150 Bars Cleaner
  1. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removing the reel handle: step 1, image 1 of 2 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removing the reel handle: step 1, image 2 of 2
    • Before working on the device, make sure that the power plug is unplugged.
    • Pull the handle of the reel facing you to unclip it.
  2. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: step 2, image 1 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: step 2, image 2 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the reel: step 2, image 3 of 3
    • Unscrew the 2 fixing screws of the housing
    • Remove the housing
    • Using a flathead screwdriver, remove the clip that holds the high pressure outlet fitting from the pump to the reel.
  3. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: step 3, image 1 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: step 3, image 2 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Extraction of the reel: step 3, image 3 of 3
    • Pull the connection facing you
    • Spread the 2 retaining bearings of the reel outwards.
    • Then remove the reel one side at a time.
  4. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: step 4, image 1 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: step 4, image 2 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Removal of the front panel: step 4, image 3 of 3
    • Unscrew the 6 fixing screws marked with arrows.
    • Tilt the device on the front to access the last 2 fastening screws located under the product marked with arrows.
    • Then lay the device flat, and unscrew the plastic nut from the water inlet pipe.
  5. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: step 5, image 1 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: step 5, image 2 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the front panel: step 5, image 3 of 3
    • Remove the front panel upwards.
    • Return the product to its vertical position on its wheels.
    • Unscrew the screw indicated by the arrow to release the bearing from the reel to remove the pump outlet hose.
  6. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: step 6, image 1 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: step 6, image 2 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Uncoupling of the reel bearing: step 6, image 3 of 3
    • With the mounting screw removed, slide the bearing as indicated by the arrow.
    • Then pull up to remove the bearing from the pipe.
    • Then remove the front panel.
  7. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: step 7, image 1 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: step 7, image 2 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Access to the On/Off switch: step 7, image 3 of 3
    • Remove the button facing you.
    • Unscrew the 2 screws as indicated in order to disengage the support.
    • Then unscrew the 6 screws and remove the cover to access the electrical connection.
  8. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: step 8, image 1 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: step 8, image 2 of 3 Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Electrical disconnection: step 8, image 3 of 3
    • Remove the switch from its housing.
    • Disconnect the red power cable from the On/Off switch
  9. Change the thermal breaker - Sterwins HC 150 Bars Cleaner, Replacement of the circuit breaker: step 9, image 1 of 1
    • Insert a breaker.
Finish Line
Special thanks to these translators:
fr en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
iRobot
1 Reputation
636 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 23
All Time: 186
