Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch Replacement
    1. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Position Device: step 1, image 1 of 1
      • Place the meter face down, and the back panel and screws can be seen.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel Screws: step 2, image 1 of 2 Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel Screws: step 2, image 2 of 2
      • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
      Ask FixBot
    3. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Back Panel: step 3, image 1 of 1
      • Remove the back panel of the device by lifting upward.
      • Remove the battery from the meter before continuing.
      Ask FixBot
    4. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Unscrew Motherboard: step 4, image 1 of 2 Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Unscrew Motherboard: step 4, image 2 of 2
      • Remove the four 7mm Phillips screws holding the circuit board in place.
      Ask FixBot
    5. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove Motherboard: step 5, image 1 of 1
      • Gently lift the circuit board away from the device casing.
      • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
      Ask FixBot
    1. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Locate 'On'/'Off' Switch: step 6, image 1 of 1
      • The 'on'/'off' switch is located directly beneath the dial.
      Ask FixBot
    2. Cen-Tech Seven Function Digital Multimeter 'On'/'Off' Switch  Replacement, Remove 'On'/'Off' Switch: step 7, image 1 of 1
      • Gently remove switch from device by lifting upward.
      • Either clean or replace switch.
      Ask FixBot
5 other people completed this guide.
Rebekah Allison
154 Reputation
1 Guide authored
Clemson, Team 2-4, Benson Fall 2014 Member of Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Members
24 Guides authored
1 Guide Comment
Hi Great site love it, Where can you purchase the copper contacts and is there a technical name for them didn’t know that I could have repaired much craftsman 82040 meter by piecing out the harbor freight free meterand using the contacts which were worn out and non repairable and started to hand make them and then ran across this site. Thanks for the tutorial and being part of the solution as i am an automotive parts rebuilder keeping land fills few of good core since 1988.
Joel - Reply Share
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 30
All Time: 2,233
