Celestron HomeCast Lite 47020 Main Unit Battery Replacement
  1. Celestron HomeCast Lite 47020 Main Unit Battery Replacement, Main Unit Battery: step 1, image 1 of 1
    • Power off your Celestron HomeCast Lite 47020 and unplug it from any power source.
    • This will help avoid electrical hazards and prevent accidental activation during the repair.
  2. Celestron HomeCast Lite 47020 Main Unit Battery Replacement: step 2, image 1 of 3 Celestron HomeCast Lite 47020 Main Unit Battery Replacement: step 2, image 2 of 3 Celestron HomeCast Lite 47020 Main Unit Battery Replacement: step 2, image 3 of 3
    • Flip the main unit over so the bottom is facing up.
    • Use your finger to release the clip at the bottom of the battery cover and lift up.
    • Slide the battery cover out from the top.
    • Use your fingers to slide the positive end of the battery upward first, then lift the negative end to remove each battery.
    • If the old battery is damaged or leaking, wear gloves to handle it safely. Dispose of it according to local regulations.
    • When inserting the new batteries, ensure the positive and negative terminals align correctly. Press the battery gently into place.
xin zhao
243 Reputation
2 Guides authored
UC Davis, Team S18-G7, Lore Winter 2019 Member of UC Davis, Team S18-G7, Lore Winter 2019
UCD-LORE-W19S18G7
4 Members
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 209
