Replacing the ball bearing in Squeaky Ceiling Fan
Video Overview
  1. Replacing the ball bearing in Squeaky Ceiling Fan, Remove the plastic cover: step 1, image 1 of 2 Replacing the ball bearing in Squeaky Ceiling Fan, Remove the plastic cover: step 1, image 2 of 2
    • First, remove the mounting screws of the plastic cover located along the brim, farthest from the centre.
  2. Replacing the ball bearing in Squeaky Ceiling Fan, Removal of the Iron cage: step 2, image 1 of 2 Replacing the ball bearing in Squeaky Ceiling Fan, Removal of the Iron cage: step 2, image 2 of 2
    • The iron cage is firmly secured by three screws.
    • Out of the six mounting screws located along the inner circle, three of them will be the mounting screws for the iron cage.
    • Remaining six screws will be the mounting screws for the fan blade.
  3. Replacing the ball bearing in Squeaky Ceiling Fan: step 3, image 1 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 3, image 2 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 3, image 3 of 3
    • Remove the wiring from the terminal block and the capacitor from the bracket.
    • Unscrew the 13mm mounting bolt to remove the supporting rod.
  4. Replacing the ball bearing in Squeaky Ceiling Fan: step 4, image 1 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 4, image 2 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 4, image 3 of 3
    • Remove the safety cord.
    • Use plier to loosen the holder.
    • The back plate can be removed once all the electric components are removed.
  5. Replacing the ball bearing in Squeaky Ceiling Fan: step 5, image 1 of 2 Replacing the ball bearing in Squeaky Ceiling Fan: step 5, image 2 of 2
    • Be sure to keep the O-ring safe.
    • Knock off the back plate by positioning it up-side down.
  6. Replacing the ball bearing in Squeaky Ceiling Fan: step 6, image 1 of 2 Replacing the ball bearing in Squeaky Ceiling Fan: step 6, image 2 of 2
    • Use three crawl puller, to remove the bearing.
    • Spray lubricant prior to extraction.
  7. Replacing the ball bearing in Squeaky Ceiling Fan: step 7, image 1 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 7, image 2 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 7, image 3 of 3
    • Use a two crawl puller to remove the bearing located 4mm away from the tip.
    • Alternatively, it can be knocked off using a chisel from behind through the hole.
    • A long chisel becomes handy !
  8. Replacing the ball bearing in Squeaky Ceiling Fan: step 8, image 1 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 8, image 2 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 8, image 3 of 3
    • Use three sockets to level the rotor core, while giving the bearing a final push.
  9. Replacing the ball bearing in Squeaky Ceiling Fan: step 9, image 1 of 2 Replacing the ball bearing in Squeaky Ceiling Fan: step 9, image 2 of 2
    • A 3" long PVC tube of 6/8 " inner diameter, is used to install the new bearing (6302z for this model of fan).
    • Rubber mallet is used to punch the PVC tube during installation.
  10. Replacing the ball bearing in Squeaky Ceiling Fan: step 10, image 1 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 10, image 2 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 10, image 3 of 3
    • Use a rubber mallet to install the other bearing onto the shaft. Rubber mallet or wooden mallet prevents damage to the bearing.
    • The same PVC tubing can be used to give the bearing a final push.
  11. Replacing the ball bearing in Squeaky Ceiling Fan: step 11, image 1 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 11, image 2 of 3 Replacing the ball bearing in Squeaky Ceiling Fan: step 11, image 3 of 3
    • Apply mechanical grease around the inner wall of the iron cage.
    • Be sure to install the O-ring.
    • Installation of fan requires electrical knowledge. Certified personnel are required to install it back on the ceiling.
19 other people completed this guide.
SengChoy Liew
969 Reputation
3 Guides authored
5 Guide Comments
my ceiling fan would sometimes not start and making rumbling sounds (bearings) i did not want to replace or tear down so lifted plastic cover on top and liberally sprayed machine oil over exposed bearing & through slots underneath wd 40 this has cured problem perfectly just dry bearings would probably be better to use spray grease if you have --cheaper than new fan or bearings and only a few minutes work
daveorme - Reply Share
My fan was not working what probelm
Govardhan Yadagiri - Reply Share
Thanks! I took apart my fan, thank you to your precise instructions. Used lithium grease and right now, enjoying quiet fan in my bedroom
Chris murie - Reply Share
price of the ceiling fan bearing
tophan das - Reply Share
muchas gracias porel aporte , muy util y bien explicado
saludos cordiales
cuismi - Reply Share
Past 24 Hours: 6
Past 7 Days: 54
Past 30 Days: 236
All Time: 67,449
