Caterpillar B15 LCD Replacement
    1. Caterpillar B15 LCD Replacement, Caterpillar B15 Teardown: step 1, image 1 of 1
      • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
      Ask FixBot
    2. Caterpillar B15 LCD Replacement: step 2, image 1 of 2 Caterpillar B15 LCD Replacement: step 2, image 2 of 2
      • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
      Ask FixBot
    3. Caterpillar B15 LCD Replacement: step 3, image 1 of 2 Caterpillar B15 LCD Replacement: step 3, image 2 of 2
      • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone.
      Ask FixBot
    4. Caterpillar B15 LCD Replacement: step 4, image 1 of 2 Caterpillar B15 LCD Replacement: step 4, image 2 of 2
      • With the back cover removed, locate and remove the Phillips screw pictured top-center, and the two torx screws above and to either side of the Phillips screw. A T-5 bit is required for removal of the torx screws.
      • WARNING: Proceeding beyond this point will void the warranty for this device.
      Ask FixBot
    5. Caterpillar B15 LCD Replacement: step 5, image 1 of 1
      • Next, remove the two torx (star-shaped) screws below the battery. These screws help to secure the outer shell of the phone around the motherboard. A T-5 bit is required for removal.
      Ask FixBot
    6. Caterpillar B15 LCD Replacement: step 6, image 1 of 1
      • There are three remaining screws on each long side of the phone. A small hex bit is required for removal.
      Ask FixBot
    7. Caterpillar B15 LCD Replacement: step 7, image 1 of 1
      • There is one more Phillips screw remaining. It is located beneath the headphone cover.
      Ask FixBot
    8. Caterpillar B15 LCD Replacement: step 8, image 1 of 1
      • With all screws removed, the back and side pieces should come off the front of the phone, exposing the motherboard and various components as shown.
      Ask FixBot
    9. Caterpillar B15 LCD Replacement: step 9, image 1 of 1
      • With all screws removed, move around the motherboard, carefully prying it from the remaining shell.
      Ask FixBot
    10. Caterpillar B15 LCD Replacement: step 10, image 1 of 1
      • Finally, disconnect the chip seen in the upper right, and the board should pull away from the rest of the phone.
      Ask FixBot
    11. Caterpillar B15 LCD Replacement: step 11, image 1 of 1
      • Congratulations. You have successfully disassembled the Caterpillar B15.
      Ask FixBot
    1. Caterpillar B15 LCD Replacement, LCD: step 12, image 1 of 1
      • With the device completely disassembled, the LCD can easily be accessed. It is pictured here, in which it adheres to the front of the motherboard.
      Ask FixBot
    2. Caterpillar B15 LCD Replacement: step 13, image 1 of 1
      • The LCD is held to the board by an adhesive, and will peel away with either a spudger or by hand. Disconnect any ribbon cables if applicable.
      Ask FixBot
    3. Caterpillar B15 LCD Replacement: step 14, image 1 of 1
      • Installing the new LCD is the reverse of removing the old one. The 2mm 3M adhesive tape listed in the guide is recommended for fixing the new display to the board.
      Ask FixBot
9 other people completed this guide.
Geoffrey Mosdell
1,119 Reputation
5 Guides authored
USF Tampa, Team 4-7, Brown Fall 2014 Member of USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 86
All Time: 7,689
