This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓A short guide on how to open the Casio G-Shock G7900 and replace the battery.
Parts
Tools
First, you must remove the 2 plastic tabs for better handling. Having already done this, do it on your own or add a step yourself!
Using the 00 Phillips screwdriver, unscrew the 4 screws from the back plate.
During reassembly, be sure not to forget the rubber washer (2nd photo).
And there you go, you now have access to the inside of the watch!
To remove the main dial, you can use the small tab outlined in green here. Be careful, it may be fragile!
If you only wish to change the battery, it is not necessary to remove the watch dial. It is actually safer to leave it in, as removing it puts the dial at risk!
To unlock the battery, you will need to remove the protector film
En partant du bout qui dépasse, utilisez une fine pince pour le décoller sans trop forcer. Attention, il y a des branches dessous donc ne forcez pas trop !
Comme visible sur la 2° photo, il suffit de décaler l’accroche vers l’extérieur pour la débloquer. Une pince fine fait parfaitement l’affaire.
Pour la remettre, il suffit donc d’appuyer dessus et d’entendre le clic.
There you go, you're all set! Replace the battery with a new one (CR 2025) and everything is good to go.
Please let me know in the comments if any details are missing or if you have any questions!
Special thanks to these translators:
100%
Maxime Pigeau is helping us fix the world! Want to contribute?
Start translating ›
