Casio G-Shock G8900A-1CR Battery Replacement.
  1. Casio G-Shock G8900A-1CR Battery Replacement., Battery: step 1, image 1 of 3 Casio G-Shock G8900A-1CR Battery Replacement., Battery: step 1, image 2 of 3 Casio G-Shock G8900A-1CR Battery Replacement., Battery: step 1, image 3 of 3
    • Use a Phillips #00 screwdriver to unscrew the four 2.0mm screws on the back cover of the watch.
  2. Casio G-Shock G8900A-1CR Battery Replacement.: step 2, image 1 of 2 Casio G-Shock G8900A-1CR Battery Replacement.: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the back cover.
    • Use tweezers to remove the rubber gasket.
  3. Casio G-Shock G8900A-1CR Battery Replacement.: step 3, image 1 of 1
    • Use tweezers to remove the rubber cover.
  4. Casio G-Shock G8900A-1CR Battery Replacement.: step 4, image 1 of 2 Casio G-Shock G8900A-1CR Battery Replacement.: step 4, image 2 of 2
    • Use tweezers to press in the gap in the opening of the battery protection.
    • The battery protection should pop open.
    • Do not apply too much force.
    • Raise the battery protection.
  5. Casio G-Shock G8900A-1CR Battery Replacement.: step 5, image 1 of 1
    • Use tweezers to remove the old CR2016 3V battery.
    • Avoid using your fingers for the process to prevent static discharge and potential damage.
  6. Casio G-Shock G8900A-1CR Battery Replacement.: step 6, image 1 of 2 Casio G-Shock G8900A-1CR Battery Replacement.: step 6, image 2 of 2
    • Insert the new CR2016 3V battery into the compartment.
    • Align the new battery's positive and negative sides with the orientation of the previous one.
    • Close the battery protection by gently pressing on it.
    • Press until it audibly clicks into place.
  7. Casio G-Shock G8900A-1CR Battery Replacement.: step 7, image 1 of 1
    • Put the rubber gasket and cover back in their original position, and tighten the four 2.0mm screws using a Phillips #00 screwdriver.
  8. Casio G-Shock G8900A-1CR Battery Replacement.: step 8, image 1 of 1
    • Press the [ADJUST] button until the seconds starts blinking.
    • Press the [MODE] button to go through the settings until you get to the hour, minute, and seconds adjustment.
    • Press the [FORWARD] button to scroll forwards, for example, from 9 to 10 o'clock.
    • Press the [REVERSE] button to scroll backwards, for example, from 10 to 9 o'clock.
    • For more features and settings, consult the user manual.
When you need to dispose of your CR2016 3V battery, please take them to a battery recycling center, use a battery drop-off location, or arrange a battery pick-up through your local government's website.
Stephen
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 162
All Time: 2,653
