Casio FX-991CW Battery Replacement
    1. Casio FX-991CW Battery Replacement, Removing the Battery Cover: step 1, image 1 of 3 Casio FX-991CW Battery Replacement, Removing the Battery Cover: step 1, image 2 of 3 Casio FX-991CW Battery Replacement, Removing the Battery Cover: step 1, image 3 of 3
      • First, take the protective cover off the calculator.
      • Then, turn the calculator over.
      • Remove the Philips screw that holds the battery cover in place in the top-right corner.
      • Then lift the cover off by lifting the right side of the cover up, and slide it out.
      Ask FixBot
    2. Casio FX-991CW Battery Replacement, Removing the Battery: step 2, image 1 of 2 Casio FX-991CW Battery Replacement, Removing the Battery: step 2, image 2 of 2
      • Take a pointy, flat tool, like a flathead screwdriver, to pry the battery out of the compartment.
      Ask FixBot
    3. Casio FX-991CW Battery Replacement, Installing the Battery: step 3, image 1 of 2 Casio FX-991CW Battery Replacement, Installing the Battery: step 3, image 2 of 2
      • Insert the new battery into the calculator by sliding it into place, then pushing it down, to ensure a good connection.
      Ask FixBot
    4. Casio FX-991CW Battery Replacement, Installing the Cover: step 4, image 1 of 3 Casio FX-991CW Battery Replacement, Installing the Cover: step 4, image 2 of 3 Casio FX-991CW Battery Replacement, Installing the Cover: step 4, image 3 of 3
      • Slide the battery cover into place.
      • Then install the screw.
      • Tighten the screw.
      • NOTE: BELOW THIS GUIDE, THERE IS A NOTE THAT SAYS "TO REASSEMBLE THIS DEVICE, FOLLOW THESE DIRECTIONS IN REVERSE ORDER." DO NOT FOLLOW THAT STEP, AS THIS GUIDE IS COMPLETE!
      Ask FixBot
Musa Umar
109 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 30
Past 30 Days: 113
All Time: 1,081
