Shop the Holiday Gift Guide
Casio FX-115MS Back Plate Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
9
All Time:
242
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
In the event that your back plate is cracked or broken you will need to remove the back plate. This guide will show you how.
Tools
    1. Casio FX-115MS Back Plate Replacement, Back Plate: step 1, image 1 of 1
      • Remove the 6 screws, which are 5mm long, using a PH1 screwdriver.
      Ask FixBot
    2. Casio FX-115MS Back Plate Replacement: step 2, image 1 of 3 Casio FX-115MS Back Plate Replacement: step 2, image 2 of 3 Casio FX-115MS Back Plate Replacement: step 2, image 3 of 3
      • Use plastic spudger to separate backplate from the front-plate. Place the flat end of the spudger in the seam between the front and back, near one end of the calculator. Then slide the spudger towards the calculator's center. The two sides will pop free from each other as you go through it with the spudger.
      Ask FixBot
Author
with
Lindsey Griffin
472 Reputation
3 Guides authored
USF Tampa, Team 2-2, Nance Fall 2016 Member of USF Tampa, Team 2-2, Nance Fall 2016
USFT-NANCE-F16S2G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 242
