Introduction
This guide will show you how to remove the LCD screen off the Casio Camera.
Remove the two screws on the side of the speakers with the Phillips 00 Screwdriver, on the portion of the camera that is a part of the back casing.
Remove the screws on the opposite of the speakers.
Label the screws accordingly and add to the sorting tray.
Once all screws have been removed, gently pry open the bottom casing.
Use the tweezers to carefully remove the ribbon from the LCD screen- NOT from the back casing itself.
Set the bottom casing aside.
Use the tweezers to pry the LCD screen off from the openings. There are 5 spots that the tweezers can go in to pry the LCD screen off (see attached pictures).
Use the tweezers to lift up the LCD screen.
Grab the LCD screen with the index finger and thumb, leave the ribbon attached to the screen and leave it on the side.
Under the LCD screen you will see an LCD casing. You will want to GENTLY pry this off using the tweezers.
Use the tweezers to flip open the connectors holding the ribbon.
Pull out the LCD screen with the ribbon from the camera.
Reconnect the LCD ribbon to the connectors and flip back down.
Ribbon should be inserted straight in and to the right side.
Reattach the back casing as well as the small ribbon with it to the camera body.
Be carefully reattaching the case. Using both hands might help.
Locate the labeled screws from Step 2-on the bottom of the camera.
These are the longer screws. Screw them back in.
Locate the labeled screws from Step 1 and Step 3-on the side of the camera.
These are the shorter screws. Screw them back in.
Congratulations! Your camera has been reassembled.
