Once all screws have been removed, gently pry open bottom casing.
With tweezers, carefully remove ribbon from LCD screen.
Set bottom casing aside.
Flip open the connector holding the ribbon.
Pull out the LCD screen with the ribbon from the camera.
Remove two screws on the side where the battery is located.
Remove the lanyard loop after the screws come off.
Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
On the front of the camera near the flash flip the connector holding the ribbon.
Remove the ribbon from the connector.
Carefully remove the L shaped frame from the camera.
At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
Pop the frame off the bumps and tabs.
