Repairing Casio Exilim EX-Z850 Flash Assembly
  1. Repairing Casio Exilim EX-Z850 Flash Assembly, Flash Assembly: step 1, image 1 of 1
    • Remove the four screws on the side of the speaker.
  2. Repairing Casio Exilim EX-Z850 Flash Assembly: step 2, image 1 of 1
    • Remove the two back screws on the bottom of the camera.
    • Note: Bottom screws are longer than the top ones, so label accordingly for easy reassembly.
  3. Repairing Casio Exilim EX-Z850 Flash Assembly: step 3, image 1 of 1
    • Remove the four screws on the side opposite of the speaker.
  4. Repairing Casio Exilim EX-Z850 Flash Assembly: step 4, image 1 of 2 Repairing Casio Exilim EX-Z850 Flash Assembly: step 4, image 2 of 2
    • Once all screws have been removed, gently pry open bottom casing.
    • With tweezers, carefully remove ribbon from LCD screen.
    • Set bottom casing aside.
  5. Repairing Casio Exilim EX-Z850 Flash Assembly: step 5, image 1 of 3 Repairing Casio Exilim EX-Z850 Flash Assembly: step 5, image 2 of 3 Repairing Casio Exilim EX-Z850 Flash Assembly: step 5, image 3 of 3
    • Gently pry apart the top casing using tweezers.
    • Set the top casing aside.
  6. Repairing Casio Exilim EX-Z850 Flash Assembly: step 6, image 1 of 2 Repairing Casio Exilim EX-Z850 Flash Assembly: step 6, image 2 of 2
    • Use tweezers or prongs to pry the LCD screen off from the opening.
    • Note: The bottom of the LCD screen is attached to the frame by a few pieces of black tape.
  7. Repairing Casio Exilim EX-Z850 Flash Assembly: step 7, image 1 of 2 Repairing Casio Exilim EX-Z850 Flash Assembly: step 7, image 2 of 2
    • Lift up the LCD screen, slowly move it to the other side.
  8. Repairing Casio Exilim EX-Z850 Flash Assembly: step 8, image 1 of 2 Repairing Casio Exilim EX-Z850 Flash Assembly: step 8, image 2 of 2
    • Pry off the LCD casing.
  9. Repairing Casio Exilim EX-Z850 Flash Assembly: step 9, image 1 of 3 Repairing Casio Exilim EX-Z850 Flash Assembly: step 9, image 2 of 3 Repairing Casio Exilim EX-Z850 Flash Assembly: step 9, image 3 of 3
    • Flip open the connector holding the ribbon.
    • Pull out the LCD screen with the ribbon from the camera.
  10. Repairing Casio Exilim EX-Z850 Flash Assembly: step 10, image 1 of 2 Repairing Casio Exilim EX-Z850 Flash Assembly: step 10, image 2 of 2
    • Remove two screws on the side where the battery is located.
    • Remove the lanyard loop after the screws come off.
    • Slowly pull the side casing so it becomes dislocated from the top of the camera frame.
  11. Repairing Casio Exilim EX-Z850 Flash Assembly: step 11, image 1 of 2 Repairing Casio Exilim EX-Z850 Flash Assembly: step 11, image 2 of 2
    • On the front of the camera near the flash flip the connector holding the ribbon.
    • Remove the ribbon from the connector.
  12. Repairing Casio Exilim EX-Z850 Flash Assembly: step 12, image 1 of 3 Repairing Casio Exilim EX-Z850 Flash Assembly: step 12, image 2 of 3 Repairing Casio Exilim EX-Z850 Flash Assembly: step 12, image 3 of 3
    • Carefully remove the L shaped frame from the camera.
    • At the bottom of the camera the L shaped frame is being held in by two plastic bumps and a metal tab.
    • Pop the frame off the bumps and tabs.
    • Note: There is a yellow and orange wire soldered onto the camera. Be careful not to pull them off.
  13. Repairing Casio Exilim EX-Z850 Flash Assembly: step 13, image 1 of 2 Repairing Casio Exilim EX-Z850 Flash Assembly: step 13, image 2 of 2
    • This is the flash assembly.
    • It needs to be removed with soldering points circled.
Christian
320 Reputation
3 Guides authored
Cal Poly, Team 4-38, Regan Winter 2011 Member of Cal Poly, Team 4-38, Regan Winter 2011
CPSU-REGAN-W11S4G38
4 Members
13 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 2,810
