Casio CZ-1000 Display Screen Replacement
    1. Casio CZ-1000 Display Screen Replacement, Backplate: step 1, image 1 of 2 Casio CZ-1000 Display Screen Replacement, Backplate: step 1, image 2 of 2
      • Use a Phillips #1 screwdriver to remove the eleven 7.5 mm screws securing the back plate.
      Ask FixBot
    2. Casio CZ-1000 Display Screen Replacement: step 2, image 1 of 3 Casio CZ-1000 Display Screen Replacement: step 2, image 2 of 3 Casio CZ-1000 Display Screen Replacement: step 2, image 3 of 3
      • Using a Phillips #1 screwdriver, remove all 14 5.5 mm screws from the two motherboards.
      • These screws secure the motherboards to the keyboard assembly and the dial on the right side.
      Ask FixBot
    3. Casio CZ-1000 Display Screen Replacement: step 3, image 1 of 3 Casio CZ-1000 Display Screen Replacement: step 3, image 2 of 3 Casio CZ-1000 Display Screen Replacement: step 3, image 3 of 3
      • Carefully cut the zip tie located in the right-hand corner using a pair of scissors or wire cutters.
      • Be sure to avoid cutting any nearby wires or components.
      • Gently slide all the plugs out of their sockets.
      • This will prevent them from catching on anything or damaging the connectors as you lift.
      Ask FixBot
    1. Casio CZ-1000 Display Screen Replacement, Display Screen: step 4, image 1 of 2 Casio CZ-1000 Display Screen Replacement, Display Screen: step 4, image 2 of 2
      • Pull out the orange 24 pin connector.
      • Pull on the orange plastic piece and not the wires. Pulling on the wires can potentially damage the device.
      Ask FixBot
    2. Casio CZ-1000 Display Screen Replacement: step 5, image 1 of 2 Casio CZ-1000 Display Screen Replacement: step 5, image 2 of 2
      • Remove the four 7.5 mm screws that are holding down the metal sheets using a Phillips #1 screwdriver.
      • Set the sheet to the side for now.
      Ask FixBot
    3. Casio CZ-1000 Display Screen Replacement: step 6, image 1 of 3 Casio CZ-1000 Display Screen Replacement: step 6, image 2 of 3 Casio CZ-1000 Display Screen Replacement: step 6, image 3 of 3
      • Remove the four 5.5 mm screws from the corners of the display screen using a Phillips #1 screwdriver.
      • Lift the side of the display screen that is closer to you and then pull out the screen.
      Ask FixBot
Ayman Benbrahim
97 Reputation
1 Guide authored
Cuesta, Team 60-3, Krynen Fall 2024 Member of Cuesta, Team 60-3, Krynen Fall 2024
CUESTA-KRYNEN-F24S60G3
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 60
All Time: 365
