Casio CTK-3200 Side Panel Replacement
    1. Casio CTK-3200 Side Panel Replacement, Center Front Panel: step 1, image 1 of 2 Casio CTK-3200 Side Panel Replacement, Center Front Panel: step 1, image 2 of 2
      • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
      Ask FixBot
    2. Casio CTK-3200 Side Panel Replacement: step 2, image 1 of 1
      • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
      • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
      • If the panel is not easily removable, make sure all the screws are removed from the back.
      Ask FixBot
    1. Casio CTK-3200 Side Panel Replacement, Side Panel: step 3, image 1 of 2 Casio CTK-3200 Side Panel Replacement, Side Panel: step 3, image 2 of 2
      • Remove all eight 10 mm Phillips #1 screws that secure the side panels.
      Ask FixBot
    2. Casio CTK-3200 Side Panel Replacement: step 4, image 1 of 1
      • Carefully remove one side panel at a time from the top of the keyboard and place it above the keyboard, making sure not to sever any connections between the yellow-colored mainboard and the side panels.
      • If the panels are not easily removable, make sure all the screws are removed from the back.
      Ask FixBot
Connor Bentley
219 Reputation
2 Guides authored
Cuesta, Team 10-4, Krynen Fall 2024 Member of Cuesta, Team 10-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 221
