Casio CTK-3200 LCD Screen Replacement
    1. Casio CTK-3200 LCD Screen Replacement, Center Front Panel: step 1, image 1 of 2 Casio CTK-3200 LCD Screen Replacement, Center Front Panel: step 1, image 2 of 2
      • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
      Ask FixBot
    2. Casio CTK-3200 LCD Screen Replacement: step 2, image 1 of 1
      • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
      • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
      • If the panel is not easily removable, make sure all the screws are removed from the back.
      Ask FixBot
    1. Casio CTK-3200 LCD Screen Replacement, Main Board: step 3, image 1 of 1
      • Make sure you are not putting too much strain on the wires that connect the yellow board to the rest of the piano.
      Ask FixBot
    2. Casio CTK-3200 LCD Screen Replacement: step 4, image 1 of 2 Casio CTK-3200 LCD Screen Replacement: step 4, image 2 of 2
      • Remove the three 12 mm Phillips #2 screws from the green PCB.
      • This step will require you to move some of the motherboard's wiring. Make sure not to separate any of the connection points.
      Ask FixBot
    3. Casio CTK-3200 LCD Screen Replacement: step 5, image 1 of 2 Casio CTK-3200 LCD Screen Replacement: step 5, image 2 of 2
      • Remove all twenty-three of the 10 mm Phillips #1 screws from the yellow circuit board.
      Ask FixBot
    4. Casio CTK-3200 LCD Screen Replacement: step 6, image 1 of 1
      • The board is now able to be removed from the center front panel. Carefully remove the board, making certain not to break the board or any of the components attached to it.
      • Make sure the center front panel is facing down for this step, as the keys will come loose from the front of the panel.
      Ask FixBot
    1. Casio CTK-3200 LCD Screen Replacement, LCD Screen: step 7, image 1 of 2 Casio CTK-3200 LCD Screen Replacement, LCD Screen: step 7, image 2 of 2
      • Carefully lift out the LCD screen.
      • If the screen has not been taken off before it might seem like it is glued to the board; this is normal.
      Ask FixBot
    2. Casio CTK-3200 LCD Screen Replacement: step 8, image 1 of 2 Casio CTK-3200 LCD Screen Replacement: step 8, image 2 of 2
      • Place your new screen face down into the center panel. Lay the screen exactly as shown in the first image, then let it fall over and land face down into place.
      • Make sure the screen is right side up. This will ensure that all of the electrical components line up correctly when the main board is re-attached to the center panel.
      Ask FixBot
Will Wright
369 Reputation
2 Guides authored
Cuesta, Team 10-4, Krynen Fall 2024 Member of Cuesta, Team 10-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G4
4 Members
42 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 35
All Time: 583
