Casio CTK-3200 Key Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
101
All Time:
716
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Casio CTK keyboard (model 3200) has keys that are sticking, not working, or broken, use this guide to replace them.
The keys are the plastic material that you press on to make the sounds. The keys are pressed and they register that motion by applying pressure down on a button below them.
It makes noise by relaying that signal through the main board, transmitting the press to the speakers which create the sound for that specific key. If any part of the key is broken, you may experience it not making noise or just sitting flat. If that is the case you will have to replace it.
Tools
    1. Casio CTK-3200 Key Replacement, Center Front Panel: step 1, image 1 of 2 Casio CTK-3200 Key Replacement, Center Front Panel: step 1, image 2 of 2
      • Remove the seven 10 mm Phillips #1 screws on the underside of the keyboard that secure the center front panel.
      Ask FixBot
    2. Casio CTK-3200 Key Replacement: step 2, image 1 of 1
      • Flip the keyboard over and remove the central panel on the front and place it above the keyboard.
      • Make sure not to sever or strain any connections between the yellow-colored main board and the central panel.
      • If the panel is not easily removable, make sure all the screws are removed from the back.
      Ask FixBot
    1. Casio CTK-3200 Key Replacement, Side Panel: step 3, image 1 of 2 Casio CTK-3200 Key Replacement, Side Panel: step 3, image 2 of 2
      • Remove all eight 10 mm Phillips #1 screws that secure the side panels.
      Ask FixBot
    2. Casio CTK-3200 Key Replacement: step 4, image 1 of 1
      • Carefully remove one side panel at a time from the top of the keyboard and place it above the keyboard, making sure not to sever any connections between the yellow-colored mainboard and the side panels.
      • If the panels are not easily removable, make sure all the screws are removed from the back.
      Ask FixBot
    1. Casio CTK-3200 Key Replacement, Key: step 5, image 1 of 2 Casio CTK-3200 Key Replacement, Key: step 5, image 2 of 2
      • Target which key(s) need to be replaced and unscrew the 10 mm Phillips #1 screws for the targeted section(s).
      • There are five different sections of white keys, you can tell the sections apart by the small gaps between them where the screws are attached.
      Ask FixBot
    2. Casio CTK-3200 Key Replacement: step 6, image 1 of 3 Casio CTK-3200 Key Replacement: step 6, image 2 of 3 Casio CTK-3200 Key Replacement: step 6, image 3 of 3
      • If the broken key(s) are white, remove the set of white keys with the broken piece.
      • If the broken key(s) are black, remove two sets of seven white keys. This will reveal the set of black keys, which are twice the length of the white sets.
      • The key sets can be troublesome to remove. To remove without further damage, make sure to lift up on the top part as shown and push the bottom part of the keys towards the bottom of the keyboard to unhook them individually.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Will Wright
369 Reputation
2 Guides authored
Cuesta, Team 10-4, Krynen Fall 2024 Member of Cuesta, Team 10-4, Krynen Fall 2024
CUESTA-KRYNEN-F24S10G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 101
All Time: 716
