Cadson Dyson Ball Disassembly
  1. Cadson Dyson Ball Disassembly, Battery: step 1, image 1 of 1
    • Remove one 9.2mm (0.36 in) screw using the PH00 screwdriver.
    • Remove the battery cover by pulling it away from the vacuum once the 9.2mm (0.36 in) screw is removed.
  2. Cadson Dyson Ball Disassembly: step 2, image 1 of 1
    • Remove batteries from the vacuum by pulling them out and away from the vacuum.
  3. Cadson Dyson Ball Disassembly, Cadson Dyson Ball Disassembly: step 3, image 1 of 1
    • Remove all seven 9.2mm (0.32 in) screws on the back of the vacuum.
    • Remember to remove battery cover and batteries as mentioned in prerequisite guide.
  4. Cadson Dyson Ball Disassembly: step 4, image 1 of 1
    • Remove the front side covers by pulling them away from the vacuum.
  5. Cadson Dyson Ball Disassembly: step 5, image 1 of 1
    • Separate the battery compartment from the ball and bead cylinder by sliding the vacuum ball away from the battery compartment.
  6. Cadson Dyson Ball Disassembly: step 6, image 1 of 1
    • Separate the bead cylinder and the fan compartment by pulling the bead cylinder away from the fan compartment.
  7. Cadson Dyson Ball Disassembly: step 7, image 1 of 1
    • Remove beads from the container.
Seldon Price
612 Reputation
5 Guides authored
IUPUI, Team S3-G5, Harley Fall 2017 Member of IUPUI, Team S3-G5, Harley Fall 2017
IUPUI-HARLEY-F17S3G5
3 Members
10 Guides authored
Past 24 Hours: 5
Past 7 Days: 36
Past 30 Days: 140
All Time: 12,272
