Caribou Coffee CC-EKV8SS7 Base Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Caribou Coffee CC-EKV8SS7  Base Disassembly, Caribou Coffee CC-EKV8SS7  Base Disassembly: step 1, image 1 of 2 Caribou Coffee CC-EKV8SS7  Base Disassembly, Caribou Coffee CC-EKV8SS7  Base Disassembly: step 1, image 2 of 2
      • Unplug the unit before disassembling to avoid electrocution.
      • Remove the five (10mm) Y screws from the bottom of the base. Three are in a triangle around the center and two are on the corners of the flat edge.
      Ask FixBot
    2. Caribou Coffee CC-EKV8SS7  Base Disassembly: step 2, image 1 of 3 Caribou Coffee CC-EKV8SS7  Base Disassembly: step 2, image 2 of 3 Caribou Coffee CC-EKV8SS7  Base Disassembly: step 2, image 3 of 3
      • Now you will need to 'unlock' the top and bottom of the base from each other. On the flat edge, there is a rectangle inset with one side cut out. Insert a metal spudger about 1/2'' in to the opening to toggle open an interior tab.
      • With the metal tool still inserted, use an opening tool between the black and silver sides to pry the base open.
      Ask FixBot
    3. Caribou Coffee CC-EKV8SS7  Base Disassembly: step 3, image 1 of 2 Caribou Coffee CC-EKV8SS7  Base Disassembly: step 3, image 2 of 2
      • Once you have the halves opened at least 1/4'', remove the metal key and rotate the base a quarter turn in any direction.
      • Continue using the spudger to pry open the base at each quarter turn until the sides separate easily.
      • The black bottom will catch on the power cord plug, to prevent total dismantlement.
      Ask FixBot
2 other people completed this guide.
Lucas Baesler
245 Reputation
2 Guides authored
UW Tacoma, Team S1-G3, Liner Summer 2017 Member of UW Tacoma, Team S1-G3, Liner Summer 2017
UWT-LINER-SU17S1G3
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 11
All Time: 183
