Carburetor Cleaning
  1. Carburetor Cleaning, Air Filter: step 1, image 1 of 3 Carburetor Cleaning, Air Filter: step 1, image 2 of 3 Carburetor Cleaning, Air Filter: step 1, image 3 of 3
    • Before starting, ensure that the engine is not running and is not hot.
    • Pull the tab until the filter cover opens. Remove the filter cover.
    • Note that the bottom of the cover is hinged.
  2. Carburetor Cleaning: step 2, image 1 of 1
    • Remove the air filter.
    • The air filter will be either an oily sponge, or an accordion-folded fabric.
    • Note that the air filter is saturated with oil. Wear gloves and use paper towels to avoid creating a mess.
  3. Carburetor Cleaning, Carburetor Cleaning: step 3, image 1 of 3 Carburetor Cleaning, Carburetor Cleaning: step 3, image 2 of 3 Carburetor Cleaning, Carburetor Cleaning: step 3, image 3 of 3
    • Locate the four bolts holding the air filter housing to the engine. Remove these bolts using the ratchet driver and the appropriately sized socket.
    • Remove the 1/4" bolts.
    • Remove the 5/16" bolts.
  4. Carburetor Cleaning: step 4, image 1 of 2 Carburetor Cleaning: step 4, image 2 of 2
    • Lift away the air filter housing.
    • Note that the housing is still attached to the engine via a bendable plastic rod.
  5. Carburetor Cleaning: step 5, image 1 of 1
    • Spray carburetor cleaner into the open carburetor.
    • You may want to wear gloves for this step, as carburetor cleaner is harmful if applied to the skin.
2 other people completed this guide.
Ethan Narad
529 Reputation
3 Guides authored
Cal Poly, Team S25-G15, Maness Spring 2018 Member of Cal Poly, Team S25-G15, Maness Spring 2018
CPSU-MANESS-S18S25G15
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 24
All Time: 1,930
