Introduction
If your kettle's handle has become warped or breaks, use this guide to replace it.
Lift the lid of the Perfectea
Remove the two 12mm Phillips #2 screws located at the brim of the pot.
Firmly grip the glass pot with one hand while using the other to slip the flat end of the plastic opening tool between the glass pot and the adhesive tape holding the handle to the glass pot.
Gently pry the adhesive tape from the glass pot. Work your way around the handle until the handle is loose and not attached to the pot anymore.
One Comment
This guide applies to the Capresso H2O kettle too. Thanks for the guide.
