Introduction
User will need spudger, plastic pry tool, and PH00 screwdriver.
Using the Phillips 00 screwdriver, remove the two 4mm top screws above the LCD screen.
Using the Phillips 00 screwdriver, remove the two 4mm side screws to the left of the LCD screen.
Using the Phillips 00 screwdriver, remove the three 4mm screws from the underside of the camera.
Using the Phillips 00 screwdriver, remove the two 3mm screws closest to the right of the LCD screen.
Using the spudger, lift the connection tab and remove the control dial's orange ribbon from motherboard.
Using spudger, lift the tab on the connector and remove the orange ribbon from motherboard (LCD screen is separated from camera).
Using the Phillips 00 screwdriver remove the seven 6mm screws from the housing plate of the LCD screen.
Using the spudger, lift the flash unit away from the metal housing (Flash is lifted to allow more room for metal housing).
Using the spudger, lift the tab on the ZIF connector and remove both orange ribbons connected to the green motherboard (Motherboard is lifted from camera).
Using the plastic pry tool, remove the motherboard and the flash unit from camera frame (Motherboard and flash unit are separated from camera).
Using the spudger, lift the tab on the connector and remove the two remaining orange ribbons from green motherboard (Motherboard is removed).
