Canon Powershot SX30 IS LCD Panel Rear Cover Replacement
  1. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement, LCD Panel Rear Cover: step 1, image 1 of 1
    • Turn the camera so the back of it is facing you.
    • Pull the LCD screen towards you in order to open it,
  2. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 2, image 1 of 2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 2, image 2 of 2
    • Unscrew the two 3 mm screws shown on the left side of the LCD screen panel using a Phillips screwdriver.
  3. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 3, image 1 of 3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 3, image 2 of 3 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 3, image 3 of 3
    • Unscrew the two 3 mm screws shown on the right side of the LCD screen panel.
  4. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 4, image 1 of 2 Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 4, image 2 of 2
    • Using the plastic opening tool, remove the rear case of the front LCD cover.
  5. Canon Powershot SX30 IS LCD Panel Rear Cover Replacement: step 5, image 1 of 1
    • Pull off the back panel of the LCD screen and the plastic wire protector. Then replace the back panel.
Ellis DeVoe
580 Reputation
5 Guides authored
Cal Poly, Team 5-12, Maness Spring 2015 Member of Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 291
