Canon Powershot SX30 IS Back Camera Housing Replacement
  1. Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: step 1, image 1 of 2 Canon Powershot SX30 IS Back Camera Housing Replacement, Back Camera Housing: step 1, image 2 of 2
    • Position the camera so that the right side is visible as shown.
    • Unscrew the two 6 mm screws shown using a screwdriver.
  2. Canon Powershot SX30 IS Back Camera Housing Replacement: step 2, image 1 of 3 Canon Powershot SX30 IS Back Camera Housing Replacement: step 2, image 2 of 3 Canon Powershot SX30 IS Back Camera Housing Replacement: step 2, image 3 of 3
    • Remove the plastic flap by pressing down on the center of the hinge and pulling on the flap with the spudger.
    • Then, unscrew the lone 6mm screw that was under the plastic flap.
  3. Canon Powershot SX30 IS Back Camera Housing Replacement: step 3, image 1 of 2 Canon Powershot SX30 IS Back Camera Housing Replacement: step 3, image 2 of 2
    • Turn the camera so that the bottom is visible, as shown.
    • Unscrew the three 4mm screws shown red using a screwdriver.
    • Unscrew the single 6mm screw.
    • Do not touch the screw shown yellow, removal is unnecessary. (Note: the top right yellow screw should be removed)
  4. Canon Powershot SX30 IS Back Camera Housing Replacement: step 4, image 1 of 1
    • Turn the camera so the back side is visible, as shown.
    • Unscrew the two 6mm screws.
  5. Canon Powershot SX30 IS Back Camera Housing Replacement: step 5, image 1 of 1
    • Gently remove the back cover using the spudger.
    • Exercise caution, as the wire inside is fragile.
  6. Canon Powershot SX30 IS Back Camera Housing Replacement: step 6, image 1 of 2 Canon Powershot SX30 IS Back Camera Housing Replacement: step 6, image 2 of 2
    • Detach the wire by lifting the small black bar that holds it to the main body of the camera.
  7. Canon Powershot SX30 IS Back Camera Housing Replacement: step 7, image 1 of 1
    • Attach the new cover onto the camera.
  8. Canon Powershot SX30 IS Back Camera Housing Replacement: step 8, image 1 of 1
    • Reattach the wire to your new rear casing.
  9. Canon Powershot SX30 IS Back Camera Housing Replacement: step 9, image 1 of 1
    • Close the back cover, and re-insert appropriate screws.
2 other people completed this guide.
Ellis DeVoe
580 Reputation
5 Guides authored
Cal Poly, Team 5-12, Maness Spring 2015 Member of Cal Poly, Team 5-12, Maness Spring 2015
CPSU-MANESS-S15S5G12
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,338
