Canon Powershot S200 Screen Replacement
  1. Canon Powershot S200 Screen Replacement, Battery: step 1, image 1 of 2 Canon Powershot S200 Screen Replacement, Battery: step 1, image 2 of 2
    • Slide the grey latch to open the battery compartment.
  2. Canon Powershot S200 Screen Replacement: step 2, image 1 of 2 Canon Powershot S200 Screen Replacement: step 2, image 2 of 2
    • Push and slide the orange retaining clip to the right to remove the battery.
  3. Canon Powershot S200 Screen Replacement: step 3, image 1 of 1
    • Remove battery from the camera.
  4. Canon Powershot S200 Screen Replacement, Motherboard: step 4, image 1 of 1
    • Remove the lanyard.
  5. Canon Powershot S200 Screen Replacement: step 5, image 1 of 1
    • Position the camera so that the bottom is facing up.
    • Remove the two 2.3mm screws beneath the name plate.
    • Remove the two 2.8 mm screws surrounding the threaded tripod mount.
  6. Canon Powershot S200 Screen Replacement: step 6, image 1 of 1
    • Remove the 3.8mm screw from the back face of the camera.
  7. Canon Powershot S200 Screen Replacement: step 7, image 1 of 1
    • Remove the two 2.3mm screws from the right face of the camera.
  8. Canon Powershot S200 Screen Replacement: step 8, image 1 of 1
    • Remove the two outer 3.2mm screws from the left side of the camera
    • Remove the two inner 3.7mm screws from the left side of the camera.
  9. Canon Powershot S200 Screen Replacement: step 9, image 1 of 1
    • Pull the back face panel away from the front end of the body. This may take some wiggling and force.
  10. Canon Powershot S200 Screen Replacement: step 10, image 1 of 2 Canon Powershot S200 Screen Replacement: step 10, image 2 of 2
    • Remove the CF card door from the left side of the camera body.
  11. Canon Powershot S200 Screen Replacement: step 11, image 1 of 2 Canon Powershot S200 Screen Replacement: step 11, image 2 of 2
    • Slide the rubber digital a/v cap out of place on the front plate.
  12. Canon Powershot S200 Screen Replacement: step 12, image 1 of 1
    • Remove the front face by sliding it off.
  13. Canon Powershot S200 Screen Replacement: step 13, image 1 of 1
    • Remove the rubber seal that covers the right side of the viewfinder.
  14. Canon Powershot S200 Screen Replacement: step 14, image 1 of 1
    • Remove the two 3.9mm screws that hold the laminated copper sheet.
  15. Canon Powershot S200 Screen Replacement: step 15, image 1 of 2 Canon Powershot S200 Screen Replacement: step 15, image 2 of 2
    • Remove the wire connections that connect along the bottom of the motherboard.
  16. Canon Powershot S200 Screen Replacement: step 16, image 1 of 1
    • Remove the single 3.8mm screw that is on the motherboard.
  17. Canon Powershot S200 Screen Replacement: step 17, image 1 of 1
    • Remove the motherboard from the main frame of the camera body.
  18. Canon Powershot S200 Screen Replacement, Screen: step 18, image 1 of 1
    • After completing the removal of the motherboard, remove the tripod mounting screws (3.4mm) on the left side
  19. Canon Powershot S200 Screen Replacement: step 19, image 1 of 1
    • Carefully pry the left side of the housing plate from the bottom of the tripod mounting plate, releasing it from the two alignment pegs next to the screws
  20. Canon Powershot S200 Screen Replacement: step 20, image 1 of 1
    • Lift the left side of the tripod mounting plate towards you, lift free the mounting plate from the rest of the assembly
    • Be careful because there are still wire connections attached to the mounting plate which you don't want to remove
  21. Canon Powershot S200 Screen Replacement: step 21, image 1 of 1
    • Remove the 2.1mm screws from the bottom and top of the screen connecting it to the housing plate
  22. Canon Powershot S200 Screen Replacement: step 22, image 1 of 1
    • Unsolder the four points at the top of the screen with a soldering iron
Anh
148 Reputation
1 Guide authored
Cal Poly, Team 20-70, Walters Spring 2011 Member of Cal Poly, Team 20-70, Walters Spring 2011
CPSU-WALTERS-S11S20G70
5 Members
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 13
All Time: 1,542
