Introduction
Remove the back encasement of the Canon PowerShot SX50 HS.
Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
Find the "A/V Out Digital" charging station and lift up the flap.
Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
