Canon PowerShot SX50 HS Rear Case Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: step 1, image 1 of 2 Canon PowerShot SX50 HS Rear Case Replacement, Rear Case: step 1, image 2 of 2
    • Remove the two Phillips #000 screws, length 5 mm, on either side of the viewfinder.
    • Remove the one Phillips #000 screw, length 4 mm, on the bottom, closer to the back side of the camera.
  2. Canon PowerShot SX50 HS Rear Case Replacement: step 2, image 1 of 2 Canon PowerShot SX50 HS Rear Case Replacement: step 2, image 2 of 2
    • Remove the two Phillips #000 screws, length 3 mm, on the left side of camera.
    • Remove the Phillips #000 screw, length 4 mm, located between the two 3 mm screws.
    • Remove the two Phillips #000 screws, length 4 mm, on the bottom left corner of the camera.
  3. Canon PowerShot SX50 HS Rear Case Replacement: step 3, image 1 of 1
    • Find the "A/V Out Digital" charging station and lift up the flap.
    • Remove the two Phillips #000 screws, length 5 mm, that are under the "A/V Out Digital" flap.
    • Remove the one Phillips #000 screw, length 5 mm, that is outside the "A/V Out Digital" flap.
  4. Canon PowerShot SX50 HS Rear Case Replacement: step 4, image 1 of 2 Canon PowerShot SX50 HS Rear Case Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to carefully start lifting up the camera's left-side panel. Then use your fingers to pry off the rest.
  5. Canon PowerShot SX50 HS Rear Case Replacement: step 5, image 1 of 3 Canon PowerShot SX50 HS Rear Case Replacement: step 5, image 2 of 3 Canon PowerShot SX50 HS Rear Case Replacement: step 5, image 3 of 3
    • Make sure the LCD screen panel, the battery compartment door, and the 'A/V Out Digital" flap are all open.
    • Using your fingers, carefully pry off the back encasement (you may need to use a plastic opening tool to help you).
    • Do not remove the back casing too far or too quickly. There is a wire ribbon attaching the back encasement to the motherboard that is very delicate.
  6. Canon PowerShot SX50 HS Rear Case Replacement: step 6, image 1 of 3 Canon PowerShot SX50 HS Rear Case Replacement: step 6, image 2 of 3 Canon PowerShot SX50 HS Rear Case Replacement: step 6, image 3 of 3
    • Find the orange wire ribbon attaching the back encasement to the I/O board in the lower right-hand corner of the camera (lens facing away).
    • Carefully lift up the brown clip holding the wire ribbon in place and pull the ribbon out of the clasp with your fingers or tweezers.
    • Be cautious when the removing the wire ribbon; it is very delicate.
  7. Canon PowerShot SX50 HS Rear Case Replacement: step 7, image 1 of 1
    • Now you can completely separate the back encasement from the rest of the camera.
Daniel Gurrola
267 Reputation
2 Guides authored
Cal Poly, Team 12-7, Lancaster Spring 2015 Member of Cal Poly, Team 12-7, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G7
5 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 1,088
