Canon PowerShot SX160 IS LCD screen Replacement
  1. Canon PowerShot SX160 IS LCD screen Replacement, LCD screen: step 1, image 1 of 3 Canon PowerShot SX160 IS LCD screen Replacement, LCD screen: step 1, image 2 of 3 Canon PowerShot SX160 IS LCD screen Replacement, LCD screen: step 1, image 3 of 3
    • Unscrew the 2-4.8mm black screws from the front of the camera using a #0 Phillips head screw driver.
    • Unscrew the 2-4.8mm black screws from the side of the camera using a #0 Phillips head screw driver.
    • Unscrew the 3-4.8mm black screws from the bottom of the camera using a #0 Phillips head screw driver.
  2. Canon PowerShot SX160 IS LCD screen Replacement: step 2, image 1 of 2 Canon PowerShot SX160 IS LCD screen Replacement: step 2, image 2 of 2
    • Use your hand to gently separate the back panel from the camera.
    • Continue to pull the panel until it becomes completely detached from the camera.
  3. Canon PowerShot SX160 IS LCD screen Replacement: step 3, image 1 of 2 Canon PowerShot SX160 IS LCD screen Replacement: step 3, image 2 of 2
    • Unscrew the 3-3.75mm silver screws from the function wheel panel of the camera using a #0 Phillips head screw driver.
    • Remove the function wheel panel from the camera and set aside.
  4. Canon PowerShot SX160 IS LCD screen Replacement: step 4, image 1 of 1
    • Unlatch the LCD ribbon connector from the camera by gently lifting up on the ribbon while pulling away from the camera.
    • Be extra cautious not to tear the ribbon.
  5. Canon PowerShot SX160 IS LCD screen Replacement: step 5, image 1 of 1
    • Using your hand, pull the LCD screen away from the camera and replace.
Jamie Secretan
1,962 Reputation
6 Guides authored
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 14
All Time: 1,397
