Disassembling Canon PowerShot SD870 IS Shutter Release Button
  1. Disassembling Canon PowerShot SD870 IS Shutter Release Button, Outer Case: step 1, image 1 of 1
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 2, image 1 of 3 Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 2, image 2 of 3 Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 2, image 3 of 3
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 3, image 1 of 1
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  4. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 4, image 1 of 2 Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 4, image 2 of 2
    • Pull the front cover from the camera by using gentle upward pressure.
  5. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 5, image 1 of 2 Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 5, image 2 of 2
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  6. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 6, image 1 of 1
    • Slide the back casing off.
  7. Disassembling Canon PowerShot SD870 IS Shutter Release Button, LCD: step 7, image 1 of 1
    • The first screw that needs to be removed is located on the bottom of the camera, on the left hand side.
    • Using a Phillips #00 screwdriver remove the 0.133in silver screw on the bottom left-hand side.
  8. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 8, image 1 of 2 Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 8, image 2 of 2
    • The second screw that needs to be removed is located on the top of the camera.
    • Using the same Phillips head screwdriver, remove the last 0.133in silver screw.
    • This will detach a silver U-shaped piece that was holding LCD screen on. Remove the piece and put it to the side.
  9. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 9, image 1 of 1
    • The LCD screen should now only be attached by the LCD data cable.
    • Lift the screen from the right side and use a small screwdriver or other small opening device to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
    • The LCD should still be connected by the backlight cable.
  10. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 10, image 1 of 2 Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 10, image 2 of 2
    • To remove the backlight cable, use another small opening device to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen should now be fully detached from the camera body.
  11. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 11, image 1 of 1
    • The LCD screen casing is connected by 4 claws located on the top and bottom on the left and right hand side.
    • Carefully disengage the claws by gently prying them off one by one.
    • Once the claws are disengaged, the back of the casing will still be connected to the front casing by the backlight cable.
    • Carefully peel the backlight cable off of the casing.
  12. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 12, image 1 of 1
    • The LCD screen and housing should now be in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD screen back housing
    • The LCD screen itself can now be removed and fixed/replaced.
  13. Disassembling Canon PowerShot SD870 IS Shutter Release Button, Shutter Release Button: step 13, image 1 of 2 Disassembling Canon PowerShot SD870 IS Shutter Release Button, Shutter Release Button: step 13, image 2 of 2
    • With the case and LCD screen removed, you are ready to remove the release button.
    • Begin by using the Philips #00 screwdriver to remove two silver 0.159in screws on the top and front of the camera.
  14. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 14, image 1 of 1
    • The top plastic piece holding the release button should be held on only by a red-and-black wire connector to the logic board.
    • Remove the connector from the logic board and detach the release button housing from the camera.
  15. Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 15, image 1 of 2 Disassembling Canon PowerShot SD870 IS Shutter Release Button: step 15, image 2 of 2
    • With the plastic housing for the release button removed from the camera, use the Philips #00 screwdriver to remove two silver 0.090in screws.
    • The release button can now be removed and fixed or replaced.
Sam
155 Reputation
5 Guides authored
Cal Poly, Team 10-45, Garner Spring 2010 Member of Cal Poly, Team 10-45, Garner Spring 2010
CPSU-GARNER-S10S10G45
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 3,465
