Canon PowerShot SD870 IS Outer Case Replacement
  1. Canon PowerShot SD870 IS Outer Case Replacement, Outer Case: step 1, image 1 of 1
    • Remove the wrist strap, if present.
    • Remove the lithium-ion battery.
  2. Canon PowerShot SD870 IS Outer Case Replacement: step 2, image 1 of 3 Canon PowerShot SD870 IS Outer Case Replacement: step 2, image 2 of 3 Canon PowerShot SD870 IS Outer Case Replacement: step 2, image 3 of 3
    • Remove the two 4 mm Phillips #00 screws on the bottom of the camera.
    • Remove the screw next to the wrist strap attachment.
    • Pull up the “A/V OUT DIGITAL” cover and remove the screw above the USB port.
  3. Canon PowerShot SD870 IS Outer Case Replacement: step 3, image 1 of 1
    • Carefully unhook the “A/V OUT DIGITAL” cover from the hinge.
  4. Canon PowerShot SD870 IS Outer Case Replacement: step 4, image 1 of 2 Canon PowerShot SD870 IS Outer Case Replacement: step 4, image 2 of 2
    • Pull the front cover from the camera by using gentle upward pressure.
  5. Canon PowerShot SD870 IS Outer Case Replacement: step 5, image 1 of 2 Canon PowerShot SD870 IS Outer Case Replacement: step 5, image 2 of 2
    • Remove the two Phillips #00 screws from the flat end of the camera.
    • Remove the black L-shaped side cover plate.
    • Remove the silver u-shaped retainer plate.
  6. Canon PowerShot SD870 IS Outer Case Replacement: step 6, image 1 of 1
    • Slide the back casing off.
Zach pelley
79 Reputation
1 Guide authored
Cal Poly, Team 10-45, Garner Spring 2010 Member of Cal Poly, Team 10-45, Garner Spring 2010
CPSU-GARNER-S10S10G45
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 8,142
