Repairing Canon PowerShot SD850 IS LCD Screen
  1. Repairing Canon PowerShot SD850 IS LCD Screen, Case: step 1, image 1 of 2 Repairing Canon PowerShot SD850 IS LCD Screen, Case: step 1, image 2 of 2
    • Remove the following 4 screws:
    • Two 2.8 mm Phillips #00 at the bottom of the camera.
    • Two 2.75 mm Phillips #00 on the opposite side of the wrist strap.
  2. Repairing Canon PowerShot SD850 IS LCD Screen: step 2, image 1 of 3 Repairing Canon PowerShot SD850 IS LCD Screen: step 2, image 2 of 3 Repairing Canon PowerShot SD850 IS LCD Screen: step 2, image 3 of 3
    • Open the A/V OUT DIGITAL flap on the side of the wrist strap.
    • Remove the 2.75 mm Phillips #00 under the A/V OUT DIGITAL flap on the side of the wrist strap.
  3. Repairing Canon PowerShot SD850 IS LCD Screen: step 3, image 1 of 2 Repairing Canon PowerShot SD850 IS LCD Screen: step 3, image 2 of 2
    • On the bottom of the camera, use your fingernail to slide the light gray tab towards the edge of the camera.
    • Slide light gray door and pull up to open the door.
    • Remove the 8.35 mm Phillips #00 next to the brown tab that holds the battery.
  4. Repairing Canon PowerShot SD850 IS LCD Screen: step 4, image 1 of 2 Repairing Canon PowerShot SD850 IS LCD Screen: step 4, image 2 of 2
    • Gently pull the front cover straight out from the camera. This will expose the wiring on the front of the camera.
  5. Repairing Canon PowerShot SD850 IS LCD Screen: step 5, image 1 of 1
    • Remove the 2.75 mm Phillips #00 next to A/V OUT DIGITAL.
  6. Repairing Canon PowerShot SD850 IS LCD Screen: step 6, image 1 of 1
    • Slide the back casing (with the screen protector) off to reveal the LCD and back wiring.
  7. Repairing Canon PowerShot SD850 IS LCD Screen, LCD Screen: step 7, image 1 of 1
    • Remove the 1.75 mm Phillips #00 located at the top left of the LCD screen.
  8. Repairing Canon PowerShot SD850 IS LCD Screen: step 8, image 1 of 1
    • Remove the two 3.4 mm Phillips #00 located at the bottom of the camera.
  9. Repairing Canon PowerShot SD850 IS LCD Screen: step 9, image 1 of 2 Repairing Canon PowerShot SD850 IS LCD Screen: step 9, image 2 of 2
    • Remove the two metal frames that hold the LCD panel in place.
  10. Repairing Canon PowerShot SD850 IS LCD Screen: step 10, image 1 of 1
    • The LCD screen should now only be attached by two LCD data cables.
    • Lift the screen from the left side and use a spudger or a small flat head screwdriver to flip the black portion of the connector upward to unlock it.
    • Carefully slide the data cable out of the connector.
  11. Repairing Canon PowerShot SD850 IS LCD Screen: step 11, image 1 of 1
    • The LCD should still be connected by the backlight cable.
    • To remove the backlight cable, use a spudger or a small flat head screwdriver to unlock the backlight cable.
    • Carefully slide out the backlight cable.
    • The LCD screen can now be fully detached from the camera body.
  12. Repairing Canon PowerShot SD850 IS LCD Screen: step 12, image 1 of 2 Repairing Canon PowerShot SD850 IS LCD Screen: step 12, image 2 of 2
    • The LCD screen and housing are now in three pieces:
    • LCD screen
    • LCD screen frame
    • LCD back housing
    • The LCD screen itself can now be removed and fixed/replaced.
Peter Tran
225 Reputation
6 Guides authored
Cal Poly, Team 20-7, Maness Fall 2010 Member of Cal Poly, Team 20-7, Maness Fall 2010
CPSU-MANESS-F10S20G7
6 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 4,150
