Canon PowerShot SD780 IS USB Port Replacement
  1. Canon PowerShot SD780 IS USB Port Replacement, USB Port: step 1, image 1 of 1
    • Begin by turning off the camera and removing the battery to avoid any shock injuries.
  2. Canon PowerShot SD780 IS USB Port Replacement: step 2, image 1 of 1
    • After the battery is removed, use a screwdriver to remove the five outermost screws on the camera to allow for a case replacement. Keep in mind that keeping track of where each screw came from is crucial for when putting the camera back together.
  3. Canon PowerShot SD780 IS USB Port Replacement: step 3, image 1 of 1
    • There are 2 screws located on the left side of the camera. These screw locations are depicted with the red circle markings in the photos. These screws are 2.0 mm long.
  4. Canon PowerShot SD780 IS USB Port Replacement: step 4, image 1 of 1
    • Remove the front panel of the camera case to expose the top left copper strip. Gently pull upward on the strip to disconnect it from the camera.
  5. Canon PowerShot SD780 IS USB Port Replacement: step 5, image 1 of 1
    • Once you remove the back portion of the camera, you will see the charging component. Remove the metallic strip on the charging component which attaches it to the motherboard.
  6. Canon PowerShot SD780 IS USB Port Replacement: step 6, image 1 of 1
    • Using a screwdriver, remove the screw that attaches the charging mechanism to the body of the camera. This will allow the mechanism to be released from the camera.
Arlene Ale
455 Reputation
4 Guides authored
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 9
All Time: 420
