Front and Rear Cover removal
  1. Front and Rear Cover removal: step 2, image 1 of 3 Front and Rear Cover removal: step 2, image 2 of 3 Front and Rear Cover removal: step 2, image 3 of 3
    • Remove the two screws from the side of the camera casing with the strap. (4mm Phillips 00)
    • Remove the two screws from the bottom of the camera. (4mm Phillips 00)
    • Remove the two screws from the right side of the camera opposite the strap. (2mm Phillips 00)
  2. Front and Rear Cover removal: step 3, image 1 of 2 Front and Rear Cover removal: step 3, image 2 of 2
    • Pull off the front cover.
    • If the top of the cover sticks, use gentle downward pressure on the retention clips above the lens to release.
    • Remove the back cover.
Jeff Casper
848 Reputation
7 Guides authored
USF Tampa, Team 17-5, Blackwell Fall 2016 Member of USF Tampa, Team 17-5, Blackwell Fall 2016
USFT-BLACKWELL-F16S17G5
3 Members
7 Guides authored
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 29
All Time: 908
