Canon PowerShot SD1100 IS Function Buttons Replacement
  1. Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: step 1, image 1 of 2 Canon PowerShot SD1100 IS Function Buttons Replacement, Front and Rear Cover: step 1, image 2 of 2
    • Remove wrist strap and battery.
  2. Canon PowerShot SD1100 IS Function Buttons Replacement: step 2, image 1 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 2, image 2 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 2, image 3 of 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Canon PowerShot SD1100 IS Function Buttons Replacement: step 3, image 1 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 3, image 2 of 3 Canon PowerShot SD1100 IS Function Buttons Replacement: step 3, image 3 of 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Canon PowerShot SD1100 IS Function Buttons Replacement: step 4, image 1 of 1
    • The cases should now be removed.
  5. Canon PowerShot SD1100 IS Function Buttons Replacement, Top Button Assembly: step 5, image 1 of 1
    • Use the spudger to disconnect the black tab.
  6. Canon PowerShot SD1100 IS Function Buttons Replacement: step 6, image 1 of 1
    • Gently pull off the shutter button assembly.
  7. Canon PowerShot SD1100 IS Function Buttons Replacement: step 7, image 1 of 1
    • Use the tweezers to disconnect the microphone cable.
  8. Canon PowerShot SD1100 IS Function Buttons Replacement: step 8, image 1 of 1
    • The shutter button assembly should now be removed.
  9. Canon PowerShot SD1100 IS Function Buttons Replacement, Function Buttons: step 9, image 1 of 1
    • With the spudger, flip up the black tab on the main ribbon.
  10. Canon PowerShot SD1100 IS Function Buttons Replacement: step 10, image 1 of 2 Canon PowerShot SD1100 IS Function Buttons Replacement: step 10, image 2 of 2
    • Gently pull straight out on the ribbon to disconnect it from the logic board.
  11. Canon PowerShot SD1100 IS Function Buttons Replacement: step 11, image 1 of 1
    • By hand, gently unfold the function button board and lift it off the frame.
  12. Canon PowerShot SD1100 IS Function Buttons Replacement: step 12, image 1 of 1
    • Congratulations! The function button board can now be replaced.
Wyatt Chan
235 Reputation
2 Guides authored
Cal Poly, Team 3-32, Regan Winter 2011 Member of Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Members
8 Guides authored
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 10
All Time: 1,969
