Installing Canon PowerShot SD1000 Motherboard
  1. Installing Canon PowerShot SD1000 Motherboard, Back Panel: step 1, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard, Back Panel: step 1, image 2 of 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Installing Canon PowerShot SD1000 Motherboard: step 2, image 1 of 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Installing Canon PowerShot SD1000 Motherboard: step 3, image 1 of 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Installing Canon PowerShot SD1000 Motherboard: step 4, image 1 of 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Installing Canon PowerShot SD1000 Motherboard: step 5, image 1 of 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Installing Canon PowerShot SD1000 Motherboard, Front Case: step 6, image 1 of 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Installing Canon PowerShot SD1000 Motherboard: step 7, image 1 of 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
  8. Installing Canon PowerShot SD1000 Motherboard, LCD Screen: step 8, image 1 of 1
    • Remove the two 2.4 mm screws located at the top of the LCD panel.
  9. Installing Canon PowerShot SD1000 Motherboard: step 9, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard: step 9, image 2 of 2
    • Pull up the metal frame surrounding the LCD screen starting at the side of the camera.
  10. Installing Canon PowerShot SD1000 Motherboard: step 10, image 1 of 1
    • Push the metal frame away from the metal tab using the spudger to detach the frame.
    • Rotate the metal frame upwards.
    • The metal framing should be attached by a metal tab towards the bottom of the camera, near the function buttons.
  11. Installing Canon PowerShot SD1000 Motherboard: step 11, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard: step 11, image 2 of 2
    • Carefully lift the metal frame from the camera.
    • Remove the black LCD screen, leaving the thin lens pieces in place.
    • BE CAREFUL; both components are attached by an orange connector ribbon and cannot be removed yet.
  12. Installing Canon PowerShot SD1000 Motherboard: step 12, image 1 of 3 Installing Canon PowerShot SD1000 Motherboard: step 12, image 2 of 3 Installing Canon PowerShot SD1000 Motherboard: step 12, image 3 of 3
    Tool used on this step:
    Buy
    • Carefully pull on the orange connector ribbon to disconnect the LCD screen.
    • The LCD screen can be pulled out of the frame before disconnecting its connector ribbon.
    • Tweezers are helpful to disconnect the ribbon.
  13. Installing Canon PowerShot SD1000 Motherboard, Flash Unit: step 13, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard, Flash Unit: step 13, image 2 of 2
    • Slide the metal frame off of the camera on the side that is closest to the flash mechanism.
  14. Installing Canon PowerShot SD1000 Motherboard: step 14, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the 2.4 mm screw that secures the flash assembly.
  15. Installing Canon PowerShot SD1000 Motherboard: step 15, image 1 of 1
    • Use the spudger to gently and carefully disconnect the flash assembly ribbon from the black connector lock.
  16. Installing Canon PowerShot SD1000 Motherboard: step 16, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard: step 16, image 2 of 2
    • Pull the flash assembly forward out of the camera to remove it.
    • BE CAREFUL when handling the flash assembly. Touching the capacitor (the black cylinder attached to the flash assembly) could shock you.
  17. Installing Canon PowerShot SD1000 Motherboard, Shutter Button: step 17, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard, Shutter Button: step 17, image 2 of 2
    • Using the spudger, take off the shutter button by prying the small tab on the front side of the camera.
  18. Installing Canon PowerShot SD1000 Motherboard, Lens: step 18, image 1 of 1
    • Remove the 2.90mm screw from the lens, near the motherboard.
  19. Installing Canon PowerShot SD1000 Motherboard: step 19, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard: step 19, image 2 of 2
    • Using the spudger remove the shutter button by prying the small tab on the front side of the camera.
  20. Installing Canon PowerShot SD1000 Motherboard: step 20, image 1 of 2 Installing Canon PowerShot SD1000 Motherboard: step 20, image 2 of 2
    • With a spudger disconnect the orange connector ribbon as shown.
    • Disconnect the orange connector ribbon that is located under the now removed shutter button.
  21. Installing Canon PowerShot SD1000 Motherboard: step 21, image 1 of 1
    • Remove the two 2.90 mm screws from the motherboard.
  22. Installing Canon PowerShot SD1000 Motherboard: step 22, image 1 of 1
    Buy
    • With Tweezers detach the bottom orange ribbon.
  23. Installing Canon PowerShot SD1000 Motherboard: step 23, image 1 of 1
    • Remove the screws shown. Start with the outside 6 (3-2.90mm & 3-2.40mm) screws on the metal frame. Then remove the 6 (2.40mm) screws on the back of the lens piece
  24. Installing Canon PowerShot SD1000 Motherboard: step 24, image 1 of 1
    • With spudger gently remove the Viewfinder Window that is directly above the lens.
  25. Installing Canon PowerShot SD1000 Motherboard: step 25, image 1 of 3 Installing Canon PowerShot SD1000 Motherboard: step 25, image 2 of 3 Installing Canon PowerShot SD1000 Motherboard: step 25, image 3 of 3
    • Detach the mother board with lens from body of camera.
    • Carefully remove the lens from the motherboard. Use tweezers to remove any of the 4 connecting ribbons from the lens.
    • Your lens has been removed from the motherboard and bottom framing.
  26. Installing Canon PowerShot SD1000 Motherboard, Motherboard: step 26, image 1 of 1
    • The motherboard (left) is now separated from the lens.
Phillip Phung
651 Reputation
9 Guides authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 33
All Time: 6,698
