Canon PowerShot SD1000 Front Case of Camera Replacement
  1. Canon PowerShot SD1000 Front Case of Camera Replacement, Back Panel: step 1, image 1 of 2 Canon PowerShot SD1000 Front Case of Camera Replacement, Back Panel: step 1, image 2 of 2
    • Remove the two 2.9 mm screws from the side panel closest to the camera lens.
  2. Canon PowerShot SD1000 Front Case of Camera Replacement: step 2, image 1 of 1
    • Remove the two 2.9 mm screws from the camera bottom panel.
  3. Canon PowerShot SD1000 Front Case of Camera Replacement: step 3, image 1 of 1
    • Remove the two 2.9 mm screws from the side panel farthest from the lens.
  4. Canon PowerShot SD1000 Front Case of Camera Replacement: step 4, image 1 of 1
    • Pull the back panel away from the camera body, starting at the end with the function buttons.
  5. Canon PowerShot SD1000 Front Case of Camera Replacement: step 5, image 1 of 1
    • Remove the small cover panel and the attached wrist strap mount.
  6. Canon PowerShot SD1000 Front Case of Camera Replacement, Front Case of Camera: step 6, image 1 of 1
    • Remove the front cover by gently pulling it away from the camera body.
  7. Canon PowerShot SD1000 Front Case of Camera Replacement: step 7, image 1 of 1
    • Place the front cover, back cover, and wrist strap mount in a safe place until you are ready for reassembly.
Phillip Phung
651 Reputation
9 Guides authored
Cal Poly, Team 8-18, Maness Winter 2012 Member of Cal Poly, Team 8-18, Maness Winter 2012
CPSU-MANESS-W12S8G18
4 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 30
All Time: 1,365
