Canon PowerShot S110 Lens Replacement
  1. Canon PowerShot S110 Lens Replacement, Battery Removal: step 1, image 1 of 2 Canon PowerShot S110 Lens Replacement, Battery Removal: step 1, image 2 of 2
    • Remove the battery by sliding open the cover on the bottom of the camera.
    • This must be done in order to avoid causing any short circuits, and to continue with disassembly.
  2. Canon PowerShot S110 Lens Replacement: step 2, image 1 of 3 Canon PowerShot S110 Lens Replacement: step 2, image 2 of 3 Canon PowerShot S110 Lens Replacement: step 2, image 3 of 3
    • Removing the following 6 Phillips screws will allow access to the inside of the camera:
    • Remove two screws on the right-side of the camera, near the HDMI port.
    • Remove two screws on the opposite side of the camera.
    • Remove the last two screws on the underside of the camera, near the tripod mounting hole.
  3. Canon PowerShot S110 Lens Replacement: step 3, image 1 of 1
    • Release all clips around the outside plastic shell, and it will lift off.
  4. Canon PowerShot S110 Lens Replacement: step 4, image 1 of 1
    • Remove the Phillips screw near the display holding the bracket in place.
    • Remove the second Phillips screw in the bottom corner, making it easier to remove the bracket.
  5. Canon PowerShot S110 Lens Replacement: step 5, image 1 of 1
    • Lift out the display mounting bracket, and set it aside.
  6. Canon PowerShot S110 Lens Replacement: step 6, image 1 of 3 Canon PowerShot S110 Lens Replacement: step 6, image 2 of 3 Canon PowerShot S110 Lens Replacement: step 6, image 3 of 3
    • Using a plastic spudger, slowly pull out the ribbon using the hole shown in the image. The first of three logic connectors connecting the display to the camera is now removed.
    • The display should now be partially disconnected from the back side of the camera.
  7. Canon PowerShot S110 Lens Replacement: step 7, image 1 of 3 Canon PowerShot S110 Lens Replacement: step 7, image 2 of 3 Canon PowerShot S110 Lens Replacement: step 7, image 3 of 3
    • In order to remove the other two connectors, the front of the case must be removed. Slowly pry around the edges using a plastic prying tool to free the case. A lens-ring piece will fall out from the inside of the camera; set this aside.
    • Remove the two screws that hold the top piece of the plastic case in. One is short, one is long.
    • With a spudger remove the two rubber pads from the top of the camera to prevent pulling on the flex cable.
  8. Canon PowerShot S110 Lens Replacement: step 9, image 1 of 3 Canon PowerShot S110 Lens Replacement: step 9, image 2 of 3 Canon PowerShot S110 Lens Replacement: step 9, image 3 of 3
    • Flip up the tab holding down this logic ribbon.
    • Flip up a second tab holding down this other ribbon; both the cables should be easily removable following this.
  9. Canon PowerShot S110 Lens Replacement: step 10, image 1 of 3 Canon PowerShot S110 Lens Replacement: step 10, image 2 of 3 Canon PowerShot S110 Lens Replacement: step 10, image 3 of 3
    • Flip up the tab and remove the last ribbon.
    • The display can now be lifted off the camera and the logic ribbons attached in the front can slide out.
  10. Canon PowerShot S110 Lens Replacement: step 11, image 1 of 2 Canon PowerShot S110 Lens Replacement: step 11, image 2 of 2
    • Using a Phillips screwdriver, remove the screws on the small circuit board at the top of the camera.
    • This will allow you to finish removing the copper panel with either your hands or a prying tool.
  11. Canon PowerShot S110 Lens Replacement: step 12, image 1 of 1
    • Using a Phillips screwdriver, remove the 8 screws attaching the metal panel to the camera.
    • During reassembly, make sure the screws go back in their specific holes, to avoid damage to the camera.
    • To remove the flash assembly, disconnect the flex cable connection, then move the flash unit out of the way.
    • Exercise caution when handling the flash unit, as there is minimal plastic protection preventing an electric shock.
  12. Canon PowerShot S110 Lens Replacement: step 14, image 1 of 1
    • Remove the Phillips screw on the front facing side of the lens.
  13. Canon PowerShot S110 Lens Replacement: step 15, image 1 of 2 Canon PowerShot S110 Lens Replacement: step 15, image 2 of 2
    • Remove the Phillips screw holding the copper plate in place.
    • Use a prying tool to lift off the copper plate.
  14. Canon PowerShot S110 Lens Replacement: step 16, image 1 of 2 Canon PowerShot S110 Lens Replacement: step 16, image 2 of 2
    • Remove the indicated screw on the front facing side of the lens using a Philips screwdriver.
    • Next, remove the small attached ribbon by lifting up the clip and gently pulling the ribbon out.
  15. Canon PowerShot S110 Lens Replacement: step 17, image 1 of 1
    • Lift the lens up to reveal the screws underneath.
    • Remove the 4 Phillips screws connecting the lens to the lens bracket.
  16. Canon PowerShot S110 Lens Replacement: step 18, image 1 of 2 Canon PowerShot S110 Lens Replacement: step 18, image 2 of 2
    • Using a prying tool, remove the lens bracket.
    • Handle your new lens carefully upon reassembly, as it's very fragile.
9 other people completed this guide.
Pierre
401 Reputation
1 Guide authored
UW Tacoma, Team 1-2, Liner SU 2015 Member of UW Tacoma, Team 1-2, Liner SU 2015
UWT-LINER-SU15S1G2
4 Members
3 Guides authored
9 Comments
Great guide. My camera broke, couple of weeks back. The lens was extended and it won't retract. It just gives the lens error message. Orders a replacement lens from eBay fro $35 and used this guide to replace it.
dhanu802 - Reply
There is a step missing, on removing the flash, one side screw and one front, above the lens, otherwise perfect. thank you so much, just as above I had a lens error and ordered a replacement for 14£ from ebay. all works now. thanks.
Adrian Salariu - Reply
Is there no other 'fix' without replacing the lens assembly on this particular "Lens error "issue?
profeduards - Reply
@profeduards: try to reseat the flexes from the aperture and IS. You can disassemble the lens to reset the position and/or remove sand but make lots of pictures of the process, and mark (with pencil) a line over the rings (from the front) to know what ring goes where when reassembling. It's possible to reassemble without (as I did, lens was extended so i couldnt) but the process is long, arduous and takes a lot of patience.
Mrten - Reply
Thanks, my Lens was bricked, and with a new Lens kit @15$ from china, it was fixed.
jeromemathey - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 95
All Time: 11,319
