Introduction
This guide will show you how to replace the motherboard in your Canon PowerShot G16 which may be necessary if the motherboard has stopped working. A broken motherboard may result in a camera that doesn't turn on, frozen menus, or general unresponsiveness.
Open the battery flap on the bottom of the camera by applying pressure and pushing in the direction of the arrow.
Remove your finger and allow the flap to pop open.
Remove the ring around the lens by simultaneously pressing the black button located at the bottom right of the ring and rotating the ring counterclockwise.
Remove the 3.3 mm screw on the right side of the viewfinder using a Phillips #00 screwdriver.
Open the port cover by lifting up the tab with your finger and remove the 3.3 mm screw underneath the cover using a Phillips #00 screwdriver.
Remove the other 3.3 mm screw below the ports using a Phillips #00 screwdriver.
Using your fingers, carefully pull the the back cover off by grabbing the bottom left of the back cover and pulling outwards.
Remove the 3.8 mm screw at the bottom right of the port cover housing using a Phillips #00 screwdriver.
Lift away the port cover housing.
Remove the 3.0 mm screw on the top of the button memory board using a Phillips #00 screwdriver.
Remove the 2.8 mm screw on the bottom of the button memory board using a Phillips #00 screwdriver.
Unlock the ZIF connector for the large connector ribbon by lifting up on the brown flap with the plastic opening tool.
Gently pull the connector straight out of the housing with your fingers.
Unplug the small connector ribbon by pulling the cable outwards from the camera using a spudger or your fingers.
Reorient the camera so that you are looking at the front.
Remove the 2.8 mm screw right above the screw holding the lens on using a Phillips #00 screwdriver.
Remove the 3.3 mm black screw to the left of the front viewfinder using a Phillips #000 screwdriver.
Reorient the camera so that you are looking at the back.
Remove the 6.8 mm screw to the left of the rear viewfinder using a Phillips #00 screwdriver.
Remove the 5.2 mm screw to the right of the rear viewfinder using a Phillips #00 screwdriver.
Remove the top 2.3 mm screw from the side with the ports using a Phillips #00 screwdriver.
Remove the 4 mm screw right below the one you just removed using a Phillips #00 screwdriver.
Reorient the camera so that you are looking at the back of the camera.
Remove the rear viewfinder casing by firmly gripping it and pulling it out bottom first.
Remove the newly uncovered 2.8 mm screw from the right of the viewfinder using a Phillips #00 screwdriver.
Remove the 4.9 mm screw from top right of the metal casing on the back using a Phillips #00 screwdriver.
Remove the 4.3 mm screw from bottom right of the metal casing on the back using a Phillips #00 screwdriver.
Reorient the camera so that you are looking at the side with the black felt circle.
Remove the 2.8 mm screw from the right side of the camera if you are looking at the front lens using a Phillips #00 screwdriver.
Remove the metal casing from the back by lifting it away from the camera.
Disconnect the cable on the top of the motherboard by lifting it up vertically using a plastic opening tool.
Disconnect the cable on the back of the camera to the left of the viewfinder by lifting it up vertically using a plastic opening tool.
Remove the top portion of the casing by firmly grasping it and pulling it upward to lift it off.
Open the two ZIF connectors by flipping them up using a plastic opening tool on the motherboard.
Disconnect the two cable ribbons by pulling them straight out.
Disconnect the lens cable from the motherboard by lifting it up vertically from the motherboard using a plastic opening tool.
Remove the small cable towards the top by pulling it straight out of its connector using tweezers or your fingers.
Remove both Screws on the bottom side of the motherboard
