Introduction
If the LCD screen of your Canon PowerShot G11 LCD is cracked or has stopped working you will need to replace it.
Open the LCD screen and turn it so the screen is facing the bottom of the camera, the screw is on the bottom of the LCD screen.
Unscrew the 3.10mm Philips #00 screw from the bottom end of the LCD screen.
Turn the LCD so that the screen is facing the top of the camera, the screw you need is on the bottom of the LCD screen.
Unscrew the 3.10mm Philips #00 screw.
Use the plastic opening tool on the indent at the top of the LCD screen to pop off the LCD case.
Once the back cover is removed unscrew the 2.22mm Phillips #00 screw that is located next to the indent handle.
On the bottom of the LCD screen carefully turn it so the screen is facing the top of the camera and unscrew the 2.22mm phillips #00 screw.
Remove the screen from the base of the LCD, do not pull because the wire strip is still attached to the LCD base.
Do not remove this wire, it is not needed when replacing the screen.
