Repairing Canon PowerShot A610 Broken Control Buttons
  1. Repairing Canon PowerShot A610 Broken Control Buttons, Batteries: step 1, image 1 of 2 Repairing Canon PowerShot A610 Broken Control Buttons, Batteries: step 1, image 2 of 2
    • Unlock the battery cover, while swinging the cover outward to open it.
  2. Repairing Canon PowerShot A610 Broken Control Buttons: step 2, image 1 of 1
    • Turn the camera over and allow the batteries to fall out.
    • Close the battery cover.
  3. Repairing Canon PowerShot A610 Broken Control Buttons, Camera Housing: step 3, image 1 of 3 Repairing Canon PowerShot A610 Broken Control Buttons, Camera Housing: step 3, image 2 of 3 Repairing Canon PowerShot A610 Broken Control Buttons, Camera Housing: step 3, image 3 of 3
    • Remove the three 3 mm screws that attach the side panel to the body of the camera.
    • Using your fingernails, pull the side panel outward to remove it.
    • Remove the two remaining 2 mm screws that attach to the frame of the camera.
  4. Repairing Canon PowerShot A610 Broken Control Buttons: step 4, image 1 of 1
    • Remove the 3 mm screw that sits at the bottom of the camera, near the front side.
    • Remove the 4 mm screw that sits at the bottom of the camera, near the back side.
  5. Repairing Canon PowerShot A610 Broken Control Buttons: step 5, image 1 of 1
    • Open the battery cover.
    • Remove the 5 mm screw that sits on the top of the battery slot.
    • Remove the three 6 mm screws that sit at the bottom of the battery slot.
  6. Repairing Canon PowerShot A610 Broken Control Buttons: step 6, image 1 of 2 Repairing Canon PowerShot A610 Broken Control Buttons: step 6, image 2 of 2
    • Open the digital A/V DC terminal cover.
    • Remove the three 4 mm screws.
    • Detach the digital A/V DC terminal.
    • When you reassemble the camera, leave the topmost screw out until after you put the top casing back.
  7. Repairing Canon PowerShot A610 Broken Control Buttons: step 7, image 1 of 1
    • Grip the sides of the top cover and gently lift it until it detaches from the camera.
    • Do not completely remove the top cover; an orange ribbon cable still connects it to the camera.
  8. Repairing Canon PowerShot A610 Broken Control Buttons: step 8, image 1 of 2 Repairing Canon PowerShot A610 Broken Control Buttons: step 8, image 2 of 2
    • With the camera upside down, pull the side of the front case that is closest to you, in an outward movement.
    • Apply some force, but pull the front case gently to prevent damage.
  9. Repairing Canon PowerShot A610 Broken Control Buttons: step 9, image 1 of 2 Repairing Canon PowerShot A610 Broken Control Buttons: step 9, image 2 of 2
    • Open the memory card slot cover.
    • Remove the 3 mm screw that sits near the bottom of the case.
  10. Repairing Canon PowerShot A610 Broken Control Buttons: step 10, image 1 of 3 Repairing Canon PowerShot A610 Broken Control Buttons: step 10, image 2 of 3 Repairing Canon PowerShot A610 Broken Control Buttons: step 10, image 3 of 3
    • Flip the LCD screen all the way open.
    • Grip both sides of top of the back case and gently pull it, in an outward movement, until the case detaches.
  11. Repairing Canon PowerShot A610 Broken Control Buttons, Control Buttons: step 11, image 1 of 2 Repairing Canon PowerShot A610 Broken Control Buttons, Control Buttons: step 11, image 2 of 2
    • Remove the back casing.
    • Flip the casing over and push on the back of the broken button with either your finger or a blunt object until it realigns into its slot.
Matthew Ramirez
625 Reputation
5 Guides authored
Cal Poly, Team 11-26, Maness Winter 2011 Member of Cal Poly, Team 11-26, Maness Winter 2011
CPSU-MANESS-W11S11G26
3 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 5,219
