Installing Canon PowerShot A590 IS Memory Card
  1. Installing Canon PowerShot A590 IS Memory Card, Open the Battery Hatch: step 1, image 1 of 1
    • Be gentle with the hatch, it is fragile.
    • *See battery replacement guide for help opening the hatch.
  2. Installing Canon PowerShot A590 IS Memory Card, Locate Memory Card: step 2, image 1 of 1
    • The memory card slot is shown here in the red rectangle.
  3. Installing Canon PowerShot A590 IS Memory Card, Remove Memory Card: step 3, image 1 of 1
    • To eject your memory card, simply press it into the camera gently, and it will spring out.
    • After it has been released from the camera, just pull it out.
  4. Installing Canon PowerShot A590 IS Memory Card, Replace Memory Card: step 4, image 1 of 1
    • To replace the memory card, make sure it is oriented with the label facing towards the front of the camera, with the contacts going in first, facing the back of the camera.
    • Push the card into the slot gently until you hear a 'click'. It will then be locked into place in the camera.
Zach
281 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 5,589
