Repairing Canon PowerShot A590 IS Flash Assembly
  1. Repairing Canon PowerShot A590 IS Flash Assembly, Batteries: step 1, image 1 of 2 Repairing Canon PowerShot A590 IS Flash Assembly, Batteries: step 1, image 2 of 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Repairing Canon PowerShot A590 IS Flash Assembly: step 2, image 1 of 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Repairing Canon PowerShot A590 IS Flash Assembly: step 3, image 1 of 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Repairing Canon PowerShot A590 IS Flash Assembly, Back Cover: step 4, image 1 of 1
    • Remove the screw located under the rubber flap on the left side of the camera using a Phillips #00 screwdriver.
  5. Repairing Canon PowerShot A590 IS Flash Assembly: step 5, image 1 of 1
    • Remove the two screws located on the other side of the camera using a Phillips #00 screwdriver.
  6. Repairing Canon PowerShot A590 IS Flash Assembly: step 6, image 1 of 1
    • Remove the three screws located at the bottom of the camera using a Phillips #00 screwdriver.
  7. Repairing Canon PowerShot A590 IS Flash Assembly: step 7, image 1 of 1
    • Open the battery cover.
    • Using the iFixit opening tool, push up gently around all edges of the camera.
  8. Repairing Canon PowerShot A590 IS Flash Assembly, Remove Lens Cover: step 8, image 1 of 1
    • Press and hold down the button shown in the blue circle.
    • While pressing the button, rotate the lens cover in a counter-clockwise direction to remove it.
  9. Repairing Canon PowerShot A590 IS Flash Assembly, Remove Front Cover: step 9, image 1 of 2 Repairing Canon PowerShot A590 IS Flash Assembly, Remove Front Cover: step 9, image 2 of 2
    • Remove the front cover of the camera.
    • This may require a bit of force.
  10. Repairing Canon PowerShot A590 IS Flash Assembly, Remove Plastic Covering: step 10, image 1 of 1
    • Remove the one (1) screw from the top of the camera, on the left side of the flash (looking from the front) using a Phillips #00 screwdriver.
    • Lift the black plastic covering off the circuit board.
  11. Repairing Canon PowerShot A590 IS Flash Assembly, Remove Green Circuit Board: step 11, image 1 of 1
    • Remove the green circuit board from the top. Looking from the front of the camera, first lift the left side up above the black peg. The board should then slide out to the left.
    • The clear flash lens may fall out. Do not worry this will not affect the camera and can easily be placed back in its spot.
  12. Repairing Canon PowerShot A590 IS Flash Assembly, Unsolder Circuit Board Cables: step 12, image 1 of 1
    • Unsolder the cables under the circuit board.
  13. Repairing Canon PowerShot A590 IS Flash Assembly: step 13, image 1 of 1
    • The flash logic board can now be removed from the camera and replaced.
Zach
281 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 15,635
