Installing Canon PowerShot A590 IS Batteries
  1. Installing Canon PowerShot A590 IS Batteries, Locate and Open Battery Hatch: step 1, image 1 of 2 Installing Canon PowerShot A590 IS Batteries, Locate and Open Battery Hatch: step 1, image 2 of 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Installing Canon PowerShot A590 IS Batteries, Locate and Remove Camera Batteries: step 2, image 1 of 1
    • This camera requires AA batteries. To remove batteries, simply allow them to fall out of the camera.
    • The clock battery cover is shown here in the purple circle. Use a fingernail to lift the battery out of the camera.
  3. Installing Canon PowerShot A590 IS Batteries, Replacing Camera Batteries: step 3, image 1 of 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
Zach
281 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
14 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 52
All Time: 7,608
