Canon PowerShot A590 IS Back Cover Replacement
  1. Canon PowerShot A590 IS Back Cover Replacement, Batteries: step 1, image 1 of 2 Canon PowerShot A590 IS Back Cover Replacement, Batteries: step 1, image 2 of 2
    • The battery hatch is on the bottom of the camera.
    • CAUTION: Locate the switch to open the hatch and push gently toward the front of the camera. Too much force can break the hatch.
    • While the switch is pushed forward, pull the cover away from the camera.
  2. Canon PowerShot A590 IS Back Cover Replacement: step 2, image 1 of 1
    • This camera requires AA batteries.
    • To remove batteries, simply allow them to fall out of the camera.
    • Use a fingernail to lift the clock battery out of the camera.
  3. Canon PowerShot A590 IS Back Cover Replacement: step 3, image 1 of 1
    • When replacing the AA batteries, verify they are oriented correctly by following the (+) and (-) signs on the camera.
  4. Canon PowerShot A590 IS Back Cover Replacement, Remove Screw Near AV Port: step 4, image 1 of 1
    • Remove the screw located under the rubber flap on the left side of the camera using a magnetic screwdriver.
  5. Canon PowerShot A590 IS Back Cover Replacement, Remove Side Screws: step 5, image 1 of 1
    • Remove the two screws located on the other side of the camera using a magnetic screwdriver
  6. Canon PowerShot A590 IS Back Cover Replacement, Remove Bottom Screws: step 6, image 1 of 1
    • Remove the three screws located at the bottom of the camera using a magnetic screwdriver.
  7. Canon PowerShot A590 IS Back Cover Replacement, Remove Back Cover: step 7, image 1 of 1
    • Open the battery cover.
    • Using the iPod tool, push up gently around all edges of the camera.
Zach
281 Reputation
6 Guides authored
Cal Poly, Team 9-19, Regan Fall 2010 Member of Cal Poly, Team 9-19, Regan Fall 2010
CPSU-REGAN-F10S9G19
4 Members
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 29
All Time: 8,576
