Introduction
This guide will guide the user towards removing the front casing and preparing the camera for future repairs.
Slide the switch on the battery cover labeled "CARD/BATT. OPEN." to the right.
While still holding the switch, pull the cover down, allowing it to release and open.
Remove the 4mm Phillips #00 screw that is located on the left side of the camera, if the display screen is facing you.
Remove the second battery cover on the bottom of camera.
Take the silver battery out of the camera.
Remove the 4mm Phillips #00 screw on the inside of the flap that hides the battery and memory card slots.
Remove the light grey, plastic piece.
Remove the plastic portion of the battery flap cover. The metal piece will remain attached.
Slightly pull on each side of the camera. It should loosen up and come apart.
If it does not pull apart right away, use a little more force.
Do not give up!
