Canon PowerShot A3400 IS Lens Replacement
  1. Canon PowerShot A3400 IS Lens  Replacement, Battery: step 1, image 1 of 1
    • Place thumb on area right next to where it says open and slide to the right to open.
  2. Canon PowerShot A3400 IS Lens  Replacement: step 2, image 1 of 1
    • Remove the battery by pushing the orange object outwards; the battery will spring up and out.
  3. Canon PowerShot A3400 IS Lens  Replacement, Plastic Case: step 3, image 1 of 2 Canon PowerShot A3400 IS Lens  Replacement, Plastic Case: step 3, image 2 of 2
    • Remove the two 5.00 mm screws in the bottom of the casing with a Philips #000 screwdriver
  4. Canon PowerShot A3400 IS Lens  Replacement: step 4, image 1 of 2 Canon PowerShot A3400 IS Lens  Replacement: step 4, image 2 of 2
    • Place the camera on to the side that has the image stabilizer label.
    • Remove the 5.00 mm screws that are on this side using the screwdriver.
  5. Canon PowerShot A3400 IS Lens  Replacement: step 5, image 1 of 1
    • Place camera on to the side with the A/V Out Digital Cover facing up.
    • Remove this visible 5.00 mm screw.
    • Pull the A/V Out Digital cover back to uncover the next step.
  6. Canon PowerShot A3400 IS Lens  Replacement: step 6, image 1 of 1
    • Remove the 5.00 mm screw from behind the cover.
  7. Canon PowerShot A3400 IS Lens  Replacement: step 7, image 1 of 1
    • Make sure the battery cover is open.
  8. Canon PowerShot A3400 IS Lens  Replacement: step 8, image 1 of 2 Canon PowerShot A3400 IS Lens  Replacement: step 8, image 2 of 2
    • Turn the camera onto the side with the A/V out Digital cover.
    • Use your finger to pull this tab to the right.
  9. Canon PowerShot A3400 IS Lens  Replacement: step 9, image 1 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 9, image 2 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 9, image 3 of 3
    • Remove the lens side by using your fingers or a spudger to pry it gently open.
    • Try to pry it loose all around that side so that it is easier to pull off.
  10. Canon PowerShot A3400 IS Lens  Replacement: step 10, image 1 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 10, image 2 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 10, image 3 of 3
    • Using your fingers, pull the screen side gently off.
    • Try to loosen it all around that side so that it is easier to try and pull it off.
  11. Canon PowerShot A3400 IS Lens  Replacement, Lens: step 11, image 1 of 3 Canon PowerShot A3400 IS Lens  Replacement, Lens: step 11, image 2 of 3 Canon PowerShot A3400 IS Lens  Replacement, Lens: step 11, image 3 of 3
    • Remove the three 5 mm screws
  12. Canon PowerShot A3400 IS Lens  Replacement: step 12, image 1 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 12, image 2 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 12, image 3 of 3
    • Pull the screen away from the main components.
    • Do not pull hard as there are some ribbons still attached to the motherboard that could be damaged if you use too much force.
  13. Canon PowerShot A3400 IS Lens  Replacement: step 13, image 1 of 2 Canon PowerShot A3400 IS Lens  Replacement: step 13, image 2 of 2
    • Lift the metal plate with the plastic opening tool.
  14. Canon PowerShot A3400 IS Lens  Replacement: step 14, image 1 of 1
    • Remove all of these 5 mm screws
  15. Canon PowerShot A3400 IS Lens  Replacement: step 15, image 1 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 15, image 2 of 3 Canon PowerShot A3400 IS Lens  Replacement: step 15, image 3 of 3
    • Gently remove the lens componenet.
    • The orange flex cables are connected to ZIF connectors. Be sure to disconnect and reconnect them properly by first unlocking the retaining flap on each connector.
tariq
131 Reputation
1 Guide authored
USF Tampa, Team 1-1, Sullivan Winter 2015 Member of USF Tampa, Team 1-1, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G1
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 869
