Canon PowerShot A2300 Front Cover Replacement
  1. Canon PowerShot A2300 Front Cover Replacement, Front Cover: step 1, image 1 of 1
    • Open the A/V Out Digital port cover on the function button side to reveal a screw.
  2. Canon PowerShot A2300 Front Cover Replacement: step 2, image 1 of 3 Canon PowerShot A2300 Front Cover Replacement: step 2, image 2 of 3 Canon PowerShot A2300 Front Cover Replacement: step 2, image 3 of 3
    • Remove all 6 screws(2.70 mm), 2 on each side and 2 on the bottom.
    • Screws are small and very easily lost.
  3. Canon PowerShot A2300 Front Cover Replacement: step 3, image 1 of 2 Canon PowerShot A2300 Front Cover Replacement: step 3, image 2 of 2
    • Open the card/battery latch by sliding the cover away from the camera in the direction indicated by the arrow.
    • Doing this gives a spot to grip on the bottom of the front cover. This will make it easier to handle when removing.
  4. Canon PowerShot A2300 Front Cover Replacement: step 4, image 1 of 1
    • Gently lift the bottom of the front cover to roughly a 30 degree angle.
  5. Canon PowerShot A2300 Front Cover Replacement: step 5, image 1 of 1
    • Pull the top of the front cover away from the camera by gripping the top of the front cover by the corners where the cover is still attached to the body.
Ashley Fincher
477 Reputation
3 Guides authored
Baylor, Team 7-14, Williams Spring 2015 Member of Baylor, Team 7-14, Williams Spring 2015
BU-WILLIAMS-S15S7G14
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 16
All Time: 549
