Up to 20% off select tools
Canon ImageFormula ScanFront 330 CMOS Battery Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
3
Past 30 Days:
9
All Time:
20
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This scanner has an embedded PC inside. After many years, the CMOS battery dies, causing a BIOS checksum error to appear when you power on the device. While you can get past the error by plugging in a USB keyboard and hitting F1, replacing the CMOS battery will resolve the issue.
    1. Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Tape the lid shut: step 1, image 1 of 1
      • Since you'll be flipping the device upside down, it can be handy to tape the lid shut using some painters tape.
      Ask FixBot
    2. Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Identify the panels to remove: step 2, image 1 of 1
      • To get to the motherboard you'll need to remove the external case pieces. The two side pieces (1 and 2) must be moved out of the way before the backplane cover (3) can be removed.
      Ask FixBot
    3. Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Remove the side panels: step 3, image 1 of 3 Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Remove the side panels: step 3, image 2 of 3 Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Remove the side panels: step 3, image 3 of 3
      • Using a flat blade screwdriver or spudger, lift the tabs out of their slot. Note you don't need to fully remove both panels, just make sure there's enough clearance space for the rear panel to be removed. There are tabs near the bottom by the square rubber feet.
      Ask FixBot
    4. Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Remove the rear panel: step 4, image 1 of 2 Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Remove the rear panel: step 4, image 2 of 2
      • Remove the rear panel in a similar manner. Note the clips on the side of this panel. If you are having difficult in removing this panel, you may need to make more room by fully removing one or both of the side panels.
      Ask FixBot
    5. Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Remove the blanking plate: step 5, image 1 of 1
      • 5 Screws secure the blanking plate in place.
      Ask FixBot
    6. Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Replace the battery: step 6, image 1 of 2 Canon ImageFormula ScanFront 330 CMOS Battery Replacement, Replace the battery: step 6, image 2 of 2
      • A vertical battery holder can be found to the right of the memory module. Gently use a flat blade screwdriver or spudger to remove it and replace with a fresh battery. Be careful not to scratch any parts of the motherboard!
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Be careful not to trap any wires as you replace the covers. When you next power on the device, you can enter the BIOS and set the clock.
notbrokeyet
36 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 20
