Shop the Holiday Gift Guide
Canon ImageCLASS MF4350d Remove Front Paneling
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
12
All Time:
335
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Very easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
This is a prerequisite to other guides that deal with the innards of the printer.
Tools
    1. Canon ImageCLASS MF4350d Remove Front Paneling, Front Paneling: step 1, image 1 of 1
      • Lift the printer lid up as shown in the photo.
      Ask FixBot
    2. Canon ImageCLASS MF4350d Remove Front Paneling: step 2, image 1 of 2 Canon ImageCLASS MF4350d Remove Front Paneling: step 2, image 2 of 2
      • Locate and remove the two 10mm side screws. There is one on each side.
      Ask FixBot
    3. Canon ImageCLASS MF4350d Remove Front Paneling: step 3, image 1 of 2 Canon ImageCLASS MF4350d Remove Front Paneling: step 3, image 2 of 2
      • Unhook the plastic panel from the printer starting from the top.
      • You may need to wiggle the panel a bit to loosen it.
      • To remove the bottom part of the paneling gently lay the printer on its back.
      • The scanner lid needs to be supported when moving the printer
      Ask FixBot
Author
with
Helena Yanez
470 Reputation
4 Guides authored
Cal Poly, Team 13-1, Forte Fall 2013 Member of Cal Poly, Team 13-1, Forte Fall 2013
CPSU-FORTE-F13S13G1
5 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 335
