Maquet Servo-U O2 Supply Replacement
    1. Maquet Servo-U O2 Supply Replacement, O2 Supply: step 1, image 1 of 1
      • Turn the inspiratory channel lock one quarter of a turn to release.
      • Lift off the inspiratory channel cover.
      • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
      Ask FixBot
    2. Maquet Servo-U O2 Supply Replacement: step 2, image 1 of 1
      • Lower the locking catch.
      Ask FixBot
    3. Maquet Servo-U O2 Supply Replacement: step 3, image 1 of 2 Maquet Servo-U O2 Supply Replacement: step 3, image 2 of 2
      • Disconnect the O2 cell connector.
      • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
      Ask FixBot
    4. Maquet Servo-U O2 Supply Replacement: step 4, image 1 of 1
      • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
      Ask FixBot
    5. Maquet Servo-U O2 Supply Replacement: step 5, image 1 of 1
      • Connect the O2 cell connector.
      • Put the O2 cell in position.
      • Close the locking catch.
      Ask FixBot
    6. Maquet Servo-U O2 Supply Replacement: step 6, image 1 of 1
      • Put the inspiratory channel cover in position.
      • Tighten the inspiratory channel lock.
      • Perform a pre-use check stated in Troubleshooting Page.
      Ask FixBot
Finish Line
Cassandra Aarrestad
627 Reputation
4 Guides authored
Cal Poly, Team S7-G2, Paton Spring 2020 Member of Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 Members
56 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 18
Past 30 Days: 69
All Time: 3,032
